MONKEYmark Posted September 28, 2003 Share Posted September 28, 2003 hi did a search on how to change fluid on automatic gearbox only came back with 1 find how much fluid does the automatic box need for a change. i bought 16 liter of the toyota stuff to be safe, sure i read somewhere it takes 12 liter to do a change? do you check the levels with the car hot and running, moving through gears to pump fluid through. just getting my torque convertor fitted and a transmission cooler too. the bloke doing work for me saying in book it says it holds 1.9 liter but its only dropped out 1liter of fluid eyefi if you on can you pm me your mobile number to pick your brains thanks the bloke doing my car has fitted the torque convertor just fitting the transmission cooler now. any help would be great thanks. http://www.mkivsupra.net/vbb/showthread.php?s=&threadid=2407&highlight=automatic+fluid+change below quote from eyfi in an old thread, there was also a link to a site but its down take the car out for a good run (30 miles ish), get the fluid nice and hot. return home, park the car nice and level. run the box thru all the gears from park, pausing in each, then back up to N, check yr fluid then. with mine, the noise would sometimes b there and other times not. i dont think yrs has just gone away. ONLY toyota type T IV auto trans fluid should b used. did u notice ONLY. there r in depth discussions on this in the bbs. heres the link that dont work http://supra.highspeedhostinggroup.net/public_html/vbb/showthread.php?s=&threadid=56&highlight=toast Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 28, 2003 Share Posted September 28, 2003 Originally posted by MONKEYmark do you check the levels with the car hot and running, moving through gears to pump fluid through. Yes box hot ,level ground. hand ands foot brake on engine running at tick over. Up and down from park through all the gears a few times to make sure the fluid is where it should be. Leave engine idleing for about one minute and check level. You should get abot 2.0l out on a drain only, I have have this much out each time I have done it. Can't remember the amount for a full change, eyefi has the figures I am sure. Flush and complete change is very different and requires care. Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted September 28, 2003 Author Share Posted September 28, 2003 thanks for input off to pick it up now, will have lots of fluid over and will get a complete flush when its all working right will email you later thanks Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted September 28, 2003 Share Posted September 28, 2003 Monkey - did mine a week or so ago and it took 1900ml. Quote Link to comment Share on other sites More sharing options...
Jake Posted May 16, 2004 Share Posted May 16, 2004 Originally posted by Terminator Yes box hot ,level ground. hand ands foot brake on engine running at tick over. Up and down from park through all the gears a few times to make sure the fluid is where it should be. Leave engine idleing for about one minute and check level. Does that mean to check it with the engine still running? Or does it mean to leave the engine idling for a minute then turn it off and check the level? I don't want to get this wrong! Quote Link to comment Share on other sites More sharing options...
Terminator Posted May 16, 2004 Share Posted May 16, 2004 Leave it running. Quote Link to comment Share on other sites More sharing options...
