addi Posted September 25, 2003 Share Posted September 25, 2003 after overheating the other day i found that there was very little water in the rad of my 6 speed 94 j spec, upon filling it up and checking for any leaks, i checked it wen i got back home (around 40 miles) to fingd it to be empty again! i have refilled since and every time within a few miles its gone, i can find no leak in the system or the rad its self and can not find no drips while running ?????? any1 any ideas cheers...from a very confused craig lol Link to comment Share on other sites More sharing options...
lovatt Posted September 25, 2003 Share Posted September 25, 2003 head gasket ? Link to comment Share on other sites More sharing options...
addi Posted September 25, 2003 Author Share Posted September 25, 2003 call me stupid but how can i check that! Link to comment Share on other sites More sharing options...
Steve Cargill Posted September 25, 2003 Share Posted September 25, 2003 Have a look at these threads and see it they are appropriate. http://www.mkivsupra.net/vbb/showthread.php?s=&threadid=10762 http://www.mkivsupra.net/vbb/showthread.php?s=&threadid=2419 Link to comment Share on other sites More sharing options...
lovatt Posted September 25, 2003 Share Posted September 25, 2003 take it to a good garage and they will do a compression test or use that blue dye stuff (very technical ) do a search for blown head gasket and see if you have any of the symptoms Link to comment Share on other sites More sharing options...
Steve Cargill Posted September 25, 2003 Share Posted September 25, 2003 Originally posted by lovatt take it to a good garage and they will do a compression test or use that blue dye stuff (very technical ) I had three different garages do all sorts of pressure tests, dye tests and road test and they failed to either diagnose it or reproduce my water loss..... Link to comment Share on other sites More sharing options...
addi Posted September 25, 2003 Author Share Posted September 25, 2003 what did u do then???? Link to comment Share on other sites More sharing options...
Steve W Posted September 25, 2003 Share Posted September 25, 2003 if it's losing it THAT fast, you'd SEE the steam out of the exhaust QUITE EASILY ! ! ! a little water creates a LOT of steam ! ! (the ones that come into us have LOADSA steam-from-exhaust and they're NOT losing it THAT fast ! !) Gas-Test (Blue Dye) on rad for combustion gases. Pressure test on rad/system for unseen leaks. (it may only leak under 'running' pressure, pumping the system up to ~11/12/13 psi simulates 'driving'). [and, YES, Steve's right... if it's POSITIVE it's GONE... if it's NEGATIVE it STILL may have gone.. doesn't ALWAYS show up pressure-test won't show water going INTERNALLY, ie. into bores/sump etc except if the actual 'pressure' drops rapidly-ish] Link to comment Share on other sites More sharing options...
Steve Cargill Posted September 25, 2003 Share Posted September 25, 2003 Originally posted by addi what did u do then???? It blew to bits one day, then there was no problem diagnosing it Have you read the threads I linked to? Link to comment Share on other sites More sharing options...
addi Posted September 26, 2003 Author Share Posted September 26, 2003 yeh i read the links and they have t=rather worried me... gunna start but purchasing a new rad cap Link to comment Share on other sites More sharing options...
Steve Cargill Posted September 26, 2003 Share Posted September 26, 2003 fingers crossed - keep us informed. Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 27, 2003 Share Posted September 27, 2003 Originally posted by Steve Cargill It blew to bits one day, then there was no problem diagnosing it There, see, you can relax now... Link to comment Share on other sites More sharing options...
addi Posted September 28, 2003 Author Share Posted September 28, 2003 well it aint the cap and ive noticed a damp block wen ive been running it so am guessing me hg has gone....any ideas on how much its gunna cost me and is it worrth me investing in a uprated kevlar one ??? Link to comment Share on other sites More sharing options...
Thorin Posted September 28, 2003 Share Posted September 28, 2003 Originally posted by addi well it aint the cap and ive noticed a damp block wen ive been running it so am guessing me hg has gone....any ideas on how much its gunna cost me and is it worrth me investing in a uprated kevlar one ??? Well it wouldn't be the first time a HG has gone on a MKIV if it has, but it is VERY rare. No idea on cost, but there is no need for anything other than a Toyota OEM one. Link to comment Share on other sites More sharing options...
Steve Cargill Posted September 28, 2003 Share Posted September 28, 2003 I think it is quoted as 12 hours labour, but that is without getting the head checked and skimmed. As Thorin says, the Toyota one is fine. Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 29, 2003 Share Posted September 29, 2003 Kevlar eh! not seen one of those for the MKIV. The stock one is steel and pretty bomb proof. Link to comment Share on other sites More sharing options...
Adam W Posted September 29, 2003 Share Posted September 29, 2003 Damp block sounds more like a ruptured coolant pipe to me, any water will be escaping into the cylinder or being forced out of the system by exhaust gas pressure. If it had blown so bad that there was a path between the coolant jacket and the side of the block you would see bits of gasket hanging out the side of the engine and it probably wouldn't fire on that cylinder (no compression). Link to comment Share on other sites More sharing options...
addi Posted September 29, 2003 Author Share Posted September 29, 2003 this is gunna have 2 be looked into a lot further! Link to comment Share on other sites More sharing options...
