Fuel Question
charlieboo
Having read the thread about which fuel to use, I am wondering why a UK-spec will run fine on normal unleaded (95 ron), but this is bad for a Jap-spec. Would I be right in assuming that it’s due to the ECU and if so, could a Jap-spec be mapped to run on 95 ron using a piggyback or similar?
Guest chiefvinso
You are not wrong. Different maps in a UK spec. It's another reason why they are so lethargic :)
LMAO I forgot that the UK spec ran on shite fuel so really is it possible that the jspec on its correct fuel is putting out similar power as the so called superior uk spec???
So say using something like an AEM EMS, it would be possible to create a map that allowed the oriental beast to run perfectly on lower octane fuel?
Obviously there are no sane reasons for doing so, but I just wanted to check my understanding of the situation.
Guest chiefvinso
I'm sure that they can be set up via a upgrade ecu or piggyback one to run on uk fuel.
And with answer to John yes/no they just lie about the UK spec :innocent:
Guest chiefvinso
All they prove is that they lie about their figures. Gentlemens agreement, my arse.
Does anyone know what rpm this claimed 280 is at as I'm sure its lower than the peak which would mean the figure would raise, no?;)
You can run it on 95ron - just don't expect it to a) like it b) be fast.
When you've put in an entire tank of fuel SUL isn't really that much more expensive. If you want a performance car but are worried about MPG then please sell up.
The stock ECU will back the timing off enough to run on UL...
