RiceRocketUk Posted February 8, 2006 Share Posted February 8, 2006 I have someone I know who wants to purchase a set of 19" wheels for a Supra TT with standard wheel arches, can someone advise the offsets required if puting a set of 8.5in on the fronts and 10in on the rear thanks Link to comment Share on other sites More sharing options...
jamesmark Posted February 8, 2006 Share Posted February 8, 2006 i would not go for 19" wheels! especially if he is lowered, i got my car lowered yeterday using eibach springs and i am rubbing on full lock on an 8" wheel on the front Link to comment Share on other sites More sharing options...
bignum Posted February 9, 2006 Share Posted February 9, 2006 also these cars where fitted with 17" wheels for a reason,,,, ok fit them 19s but dont expect it to handle very well. Link to comment Share on other sites More sharing options...
Gaz Walker Posted February 9, 2006 Share Posted February 9, 2006 i would not go for 19" wheels! especially if he is lowered, i got my car lowered yeterday using eibach springs and i am rubbing on full lock on an 8" wheel on the front Eibachs seem to lower the front of a Supra quite a bit. I'd recommend Tein S.Techs, or better still the Espilir GT Springs which only lower the car by around 20mm. 19" wheels will fit generally without issue though, only if your offsets are way out should you have problems. Your looking for a 40-50 generally, although this varies wheel to wheel. Gaz. Link to comment Share on other sites More sharing options...
