Sharpie Posted September 25, 2003 Share Posted September 25, 2003 I have my engine out at the moment and wonered if this was a good time to do any of the PITA jobs while it's out ? Link to comment Share on other sites More sharing options...
GavinL Posted September 25, 2003 Share Posted September 25, 2003 From personal experiance with a UK spec I would do these as a minimum: Front crank oil seal Rear crank oil seal Remove and blank off the EGR system as per http://www.mkiv.com Cam Belt Optionally: Camshaft oil seals Flywheel Link to comment Share on other sites More sharing options...
Steve W Posted September 25, 2003 Share Posted September 25, 2003 possible water-pump (seems 'fairly' prone and it's under the Timing Belt anyway ! ! ! !) Link to comment Share on other sites More sharing options...
Ian C Posted September 25, 2003 Share Posted September 25, 2003 I see you've taken steps to cover the engine. -Ian Link to comment Share on other sites More sharing options...
Bobbeh Posted September 25, 2003 Share Posted September 25, 2003 Originally posted by Ian C I see you've taken steps to cover the engine. -Ian Excellent reply Link to comment Share on other sites More sharing options...
Terminator Posted September 25, 2003 Share Posted September 25, 2003 Originally posted by Ian C I see you've taken steps to cover the engine. -Ian Your best ever:respekt: Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 25, 2003 Share Posted September 25, 2003 Originally posted by Ian C I see you've taken steps to cover the engine. -Ian Hall of fame. What a brilliant reply Link to comment Share on other sites More sharing options...
arnout Posted September 26, 2003 Share Posted September 26, 2003 remove trac pump chrome everything get EGR plates at my online shop (very cheap) remove turbos and install single left the head and get forged bangers in install a jun stroker kit upgrade fuel system build the engine in a lighter body for example the MA60 Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 26, 2003 Share Posted September 26, 2003 Originally posted by arnout remove trac pump chrome everything get EGR plates at my online shop (very cheap) remove turbos and install single left the head and get forged bangers in install a jun stroker kit upgrade fuel system build the engine in a lighter body for example the MA60 And if you want to go really extreme... Link to comment Share on other sites More sharing options...
Ian C Posted September 26, 2003 Share Posted September 26, 2003 Originally posted by Gaz Walker Hall of fame. What a brilliant reply Me takes a bow -Ian Link to comment Share on other sites More sharing options...
Sharpie Posted September 26, 2003 Author Share Posted September 26, 2003 very good Ian Link to comment Share on other sites More sharing options...
Dragonball Posted September 26, 2003 Share Posted September 26, 2003 Originally posted by Peter Sharp I have my engine out at the moment and wonered if this was a good time to do any of the PITA jobs while it's out ? Peter get your stuff down to Dude for chroming etc! Link to comment Share on other sites More sharing options...
