supra steveo Posted February 7, 2006 Share Posted February 7, 2006 Is there increase on BHP after installing a HKS super dragger exhaust???? cheers steve Link to comment Share on other sites More sharing options...
ardasaliah Posted February 7, 2006 Share Posted February 7, 2006 You would need to remove the cats too to gain any real BHP. However you will need a restrictor ring to keep boost at about 1.2 bar as the system will become too free flowing Link to comment Share on other sites More sharing options...
TLicense Posted February 7, 2006 Share Posted February 7, 2006 With just a HKS exhuast and 2nd CAT removed I got 320BHP at the hubs on Thors Dynopack. Literally that was the only mod to the car. Link to comment Share on other sites More sharing options...
JohnA Posted February 7, 2006 Share Posted February 7, 2006 Is there increase on BHP after installing a HKS super dragger exhaust???? It depends on the state of tune. On a stockish engine there is a minor increase in volumetric efficiency, but nothing to write home about. The bulk of power gains are due to running more boost pressure, not the wider exhaust. However, on the JSpec the cats and the rest of the exhaust are part of the wastegate control system, so modifying them also affects boost pressure. If you do run higher boost then the effects of the super dragger will be more pronounced, as it will help reduce exh backpressure a bit (BPUing has pushed it sky-high) I've got a super dragger and it's very nice:D Link to comment Share on other sites More sharing options...
lockys96 Posted February 7, 2006 Share Posted February 7, 2006 i have the super dragger cat back. what do you need for full decat, does any decat work Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 7, 2006 Share Posted February 7, 2006 Decat pipes with restrictor, fuel cut defencer, colder spark plugs and a fuel pump. Link to comment Share on other sites More sharing options...
hadyn Posted February 7, 2006 Share Posted February 7, 2006 I find the dragger to be a very heavy mild steel system. Back box does look good tho. Link to comment Share on other sites More sharing options...
Chiefgroover Posted February 7, 2006 Share Posted February 7, 2006 Super dragger on a UK spec gives approx 37bhp, remove the cats and get some more but it gets quite a bit louder when they are gone. Best sounding exhaust IMO. Link to comment Share on other sites More sharing options...
trooper Posted February 8, 2006 Share Posted February 8, 2006 I don't know how much more power I got when I changed cos I never measured it before or afterwards. Not really bovvered what the figures are. What's important is haow the car responded after the cats removed and exhaust replaced. Much better throttle response and has transformed the car from a bit sluggish to quite nippy. The sound is also very pleasing but not too loud. DO IT!! Link to comment Share on other sites More sharing options...
