koni
jamesmark
getting a set of koni's fitted tomorrow with eibach springs
but
a few people on here said that they are not adjustable, but i have been advised they are by sbits the mechanic thats looks after my soop and i saw the box tonight and they have said they are on the box............. so are they or aren't they, and whiffbitz advertises them as adjustables (never got them from there as got them same price delivered as what he does without vat and del bought from koni direct ) but i have read you can only adjust coilovers
bit confused :dontget:
so are koni's good then? obviously no match for 1k plus stuff but i have read on her that koni's and a set of eibachs is a good set up for general use and can cope with track use too (again not as good as 1k plus setups)
IMHO, Koni's and Eiback are the best off the shelf combo for the UK roads, much better than any coilovers. Just make sure you replace the top mounts too and the AR linkages.
the top mounts are next as cash is a bit tight, with the work i am getting done, also i have to invest in new alloys as the 235 on the rears is getting on my nerves (previous owners decision for 235's). the top mounts are creeking just now so by april fingers crossed i have them replaced.
AR linkages? whats that? sorry lucifer but i am still learning and is that an exspensive job?
oh AND WHAT DOES IMHO mean my head is spinning with all these abreviations (spelling)
totally agree there, its the setup i had on mine and it transformed the car :)
its not as good as chris wilsons custom setup but imo its the next best thing
Konis are adjustable off the car. I'd call them setable. I've got them and they're good value and work well. There are two different ride heights you can set them at. Fennsport sell them from stock, usually.
Replace the top mounts if they're at all worn - do them at the same time as the shock absorbers because it'll save you loads of time. I only changed one of mine because an orangutan with a big spanner had chewed it up.
