Supra-Dupra Posted February 6, 2006 Share Posted February 6, 2006 Have'nt yet gone out and attempted to take them out yet but the middle lens in the headlights on one side has died ! What's the type of bulb is required ?? I have bought some 9005 H.I.D style bulbs from ebay, are these the ones for this lens ?? Its a J-Spec 94 auto, glass headlights. Circled in the pic the lens in question. Quote Link to comment Share on other sites More sharing options...
francis Posted February 6, 2006 Share Posted February 6, 2006 Yep believe so That's your main beam, the side projector is your foglight and the centre if the full beam. Regards, Francis Quote Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2006 Share Posted February 6, 2006 Have'nt yet gone out and attempted to take them out yet but the middle lens in the headlights on one side has died ! What's the type of bulb is required ?? I have bought some 9005 H.I.D style bulbs from ebay, are these the ones for this lens ?? Its a J-Spec 94 auto, glass headlights. Circled in the pic the lens in question. You've bought the wrong bulb, you need 9006 for the UK glass headlights. UK Glass Headlights Outside = fog = H3 Middle = Low beam = 9006 Inside = High Beam = 9005 J-spec Headlights Outside = Fog = H3 Middle = Low Beam = 9006J (use 9005) Inside = High Beam = 9005J (use 9005) Quote Link to comment Share on other sites More sharing options...
Simon K Posted February 6, 2006 Share Posted February 6, 2006 I recently brought some bulbs for my j-sepc head lights, low beam. They were 9005 but you will need to gently file the outside lumps i.e. make them smaller. Also, you will need to remove the 2 plastic runners inside the socket as Jspec bulbs have one. Its not that difficult, takes 5 mins top for each bulb. I used a file, and filed the outside lumps down, and then used a stanley blade to remove both runners inside the bulb. SBK Quote Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2006 Share Posted February 6, 2006 I recently brought some bulbs for my j-sepc head lights, low beam. They were 9005 but you will need to gently file the outside lumps i.e. make them smaller. Also, you will need to remove the 2 plastic runners inside the socket as Jspec bulbs have one. Its not that difficult, takes 5 mins top for each bulb. I used a file, and filed the outside lumps down, and then used a stanley blade to remove both runners inside the bulb. SBK The bulbs will actually fit without filing the outside tabs if you jiggle them a bit they will go in. You can also unscrew the slotted part on the back of the headlight and fit them on, but I wouldn't suggest this unless you have the headlights off the car, as the screws are small and fiddly to get at. As you say just a case of removing the raised ridges from the connector, which is quite simple and once done any 9005 bulb will fit. Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 7, 2006 Author Share Posted February 7, 2006 Thanks guys ! Quote Link to comment Share on other sites More sharing options...
