Bobbeh Posted February 5, 2006 Share Posted February 5, 2006 I'm getting mixed feedback from various sources, Toyota have said for the last 12 months they need replacing, all of them because they're ligged and corroded, and I've been told by another mechanic they're fine as most of the corrosion is around the outside, and not actually on the surface of the disk. I mean they've held up fine and got me round the 'Ring ok. Although during the winter they seem to be looking a little worse for wear.. what do you think? Quote Link to comment Share on other sites More sharing options...
uk-rich Posted February 5, 2006 Share Posted February 5, 2006 i'd change them mate, good brakes are important, good time for upgrade ! Quote Link to comment Share on other sites More sharing options...
D8MOA Posted February 5, 2006 Share Posted February 5, 2006 i wouldnt have them on my car! and i bet the inside of the disc looks worse! Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted February 5, 2006 Share Posted February 5, 2006 Bob DBA golds are super for the ring, especially with endless CCX pads. Stops on a plate!. Quote Link to comment Share on other sites More sharing options...
hadyn Posted February 5, 2006 Share Posted February 5, 2006 They look better than my discs! Quote Link to comment Share on other sites More sharing options...
Alex Posted February 5, 2006 Share Posted February 5, 2006 If there is a significant lip to the edge of them then they require replacing....if not no worries. The last pic has marks on it like you've had some cailper seizing... Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 5, 2006 Author Share Posted February 5, 2006 If there is a significant lip to the edge of them then they require replacing....if not no worries. The last pic has marks on it like you've had some cailper seizing... Yeah, you're right, its the handbrake causing that on the last pic. I think I'll get them replaced. Ta for the comments. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 5, 2006 Author Share Posted February 5, 2006 Bob DBA golds are super for the ring, especially with endless CCX pads. Stops on a plate!. I was thinking TRD discs and poss pads for the Ring. How much do the golds set you back? Quote Link to comment Share on other sites More sharing options...
Sharpie Posted February 5, 2006 Share Posted February 5, 2006 Just a couple of links http://www.trdparts.jp/english/parts_monoblock.html http://www.dba.com.au/dba_catalogue_2004/HTML/home_menu.htm Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 5, 2006 Author Share Posted February 5, 2006 Pete, recommendations? Quote Link to comment Share on other sites More sharing options...
Sharpie Posted February 5, 2006 Share Posted February 5, 2006 I can't say as I have only ever used stock discs/pads and then moved to CW Fast Road pads on new stock discs. I see that Tel runs with what looks like dba gold but, not sure what pad he is using ? Tel ? (I'm sure I remember him saying that he has been through most combo's with his old purple car. And his black car is not slow so, the dba's & ?? pads must be a good combo) From Bovingdon 05 Quote Link to comment Share on other sites More sharing options...
Sharpie Posted February 5, 2006 Share Posted February 5, 2006 he has : Carbotech Pads - but which ones ?? DBA Gold discs allround Quote Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2006 Share Posted February 6, 2006 I was thinking TRD discs and poss pads for the Ring. How much do the golds set you back? Rob, I have TRD pads in stock at the moment and can get TRD, Project Mu and Endless discs, drop me an email at [email protected] if you want price list sending. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2006 Share Posted February 6, 2006 http://www.trdparts.jp/english/parts_brake-disc.html http://www.project-mu.co.jp/e/product/scr.html http://www.project-mu.co.jp/e/product/scr-pro.html http://www.endless-sport.co.jp/product-endless/disc-rotors/r_index.htm Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 6, 2006 Author Share Posted February 6, 2006 Rob, I have TRD pads in stock at the moment and can get TRD, Project Mu and Endless discs, drop me an email at [email protected] if you want price list sending. Nic, you mean discs? Thats what Im after If you have, can you email me a price for a full set for UK brake setup plz. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2006 Share Posted February 6, 2006 Nic, you mean discs? Thats what Im after Yes that's what I meant If you have, can you email me a price for a full set for UK brake setup plz. I'll email you now, but you'll need to email me back as I don't know your address to send attachment to. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 6, 2006 Author Share Posted February 6, 2006 K Quote Link to comment Share on other sites More sharing options...
Alex Posted February 6, 2006 Share Posted February 6, 2006 Bob, It can't be your handbrake causing those marks, as the handbrake is inside the disc! It's got to be the rear caliper sticking slightly.... Quote Link to comment Share on other sites More sharing options...
JohnA Posted February 6, 2006 Share Posted February 6, 2006 I'm getting mixed feedback from various sources, Toyota have said for the last 12 months they need replacing, all of them because they're ligged and corroded, and I've been told by another mechanic they're fine as most of the corrosion is around the outside, and not actually on the surface of the disk. How deep is the 'lip'? Why don't you just measure the thickness and compare it to the spec for minimum thickness? Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 6, 2006 Author Share Posted February 6, 2006 What, the width of the disc? And what is minumum thickness , do you have any details.. or should I hopefully consult the manual Quote Link to comment Share on other sites More sharing options...
JohnA Posted February 6, 2006 Share Posted February 6, 2006 thickness, yeah. Minimum: front: 28.0mm rear: 15.0mm Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 6, 2006 Author Share Posted February 6, 2006 Ta, I'll check it out Quote Link to comment Share on other sites More sharing options...
