SUPRALOOPY Posted February 4, 2006 Share Posted February 4, 2006 right here we go step by step. 1. use 120 grit dry to remove rubber stuff (messy) 2. finish off with 500 grit wet to remove bad scratches. and then use a spirit or panel wipe to clean. 3. using a grey cellulose primer (aerosol available from any good motor factor) spray even but not thick coats of primer until well covered. (enough to be able to wet flat without going through) 4. using a satin black aerosol guide coat the dry primer (spray a fine speckled coat over the grey) and then when dry using 800 grit wet flat the primer till guidecoat has gone (then you know its smooth) 5. dry the panels and spirit wipe clean. then using an aerosol of 5 wheel silver spray even coats onto the panels and wait about 5-10 mins between coats. keep doing this until you are happy that its covered and it has layed down ok. 6 it is very important to do this in the right tempreture or the paint will bloom( go milky and cloudy) best to do this indoors or in a heated garage or spraybooth. 7. BTW the product is called five wheel siver and is used for bullshitting up old steel wheels. DO NOT buy a basecoat silver as you WILL have to laquer it. hope this helps good luck, Dave Quote Link to comment Share on other sites More sharing options...
MRX Posted February 4, 2006 Share Posted February 4, 2006 Looks good mate..! thanks for the guide may try this soon.. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted February 4, 2006 Share Posted February 4, 2006 top guide will try too Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted February 4, 2006 Share Posted February 4, 2006 ooo an indoor job to wind up the girlfriend by stinking out the house with paint nice job btw Quote Link to comment Share on other sites More sharing options...
Marco Posted February 4, 2006 Share Posted February 4, 2006 Very nice! I want to do mine with metallic black... perhaps next weekend Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 4, 2006 Share Posted February 4, 2006 Looks very nice, good write up Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted February 4, 2006 Share Posted February 4, 2006 great job and guide. Quote Link to comment Share on other sites More sharing options...
Daston Posted February 4, 2006 Share Posted February 4, 2006 good timing just finished sanding mine down and was about to ask what to use as a base coat! Fingers crossed mine will look like yours when done. Quote Link to comment Share on other sites More sharing options...
Marco Posted February 4, 2006 Share Posted February 4, 2006 Does anyone know where that guide is about removing the dash panels? I searched but can't find it anymore... Quote Link to comment Share on other sites More sharing options...
Paul Posted February 4, 2006 Share Posted February 4, 2006 Gives some idea/help: http://www.mkiv.com/techarticles/boostguage/bg.htm Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 4, 2006 Author Share Posted February 4, 2006 good timing just finished sanding mine down and was about to ask what to use as a base coat! Fingers crossed mine will look like yours when done. its a single layer metalic so no laquer required..thats why i chose the five wheel silver.. Quote Link to comment Share on other sites More sharing options...
Tom S Posted February 5, 2006 Share Posted February 5, 2006 Yo Slapper !! How's it going, !! Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 5, 2006 Author Share Posted February 5, 2006 Yo Slapper !! How's it going, !! very well thanks tom and you? yolanda says hi and don't ever give her gin again:boxing: can't wait for jae so i can say hi in person:) Quote Link to comment Share on other sites More sharing options...
Tom S Posted February 5, 2006 Share Posted February 5, 2006 very well thanks tom and you? yolanda says hi and don't ever give her gin again:boxing: can't wait for jae so i can say hi in person:) sorreeeeeeeeee Taking 2 bottles this year matey !! Quote Link to comment Share on other sites More sharing options...
Marco Posted February 5, 2006 Share Posted February 5, 2006 Gives some idea/help: http://www.mkiv.com/techarticles/boostguage/bg.htm Cheers Paul Quote Link to comment Share on other sites More sharing options...
Jive Posted February 5, 2006 Share Posted February 5, 2006 That looks great and a good write up as well. I really do want to do mine now Where did you get the five wheel silver paint from or is it widely available from the likes of Halfords? How many cans did it take for the whole lot? Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 5, 2006 Author Share Posted February 5, 2006 That looks great and a good write up as well. I really do want to do mine now Where did you get the five wheel silver paint from or is it widely available from the likes of Halfords? How many cans did it take for the whole lot? its available from any good motor factors and two cans wil be more than enough:) Quote Link to comment Share on other sites More sharing options...
Marco Posted February 5, 2006 Share Posted February 5, 2006 Just a quick question: how do you remove the little ashtray light? It won't come out...? cheers Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 5, 2006 Author Share Posted February 5, 2006 Just a quick question: how do you remove the little ashtray light? It won't come out...? cheers mine was not there so can't help. but i would presume it twists or just pulls out, look for retaining tabs on the side Quote Link to comment Share on other sites More sharing options...
jackso11 Posted February 5, 2006 Share Posted February 5, 2006 Does anyone know of a good black paint to use, to get the standard look back without the rubber crap. I was going to use black with a matt laquer if I can find one, but it would be good it someone knew of a paint I didn't have to laquer! Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 5, 2006 Author Share Posted February 5, 2006 Does anyone know of a good black paint to use, to get the standard look back without the rubber crap. I was going to use black with a matt laquer if I can find one, but it would be good it someone knew of a paint I didn't have to laquer! satin black but make sure your in a dust free place when painting as you will not be able to flat and polish little bits of shit out of a satin finish:) Quote Link to comment Share on other sites More sharing options...
Marco Posted February 5, 2006 Share Posted February 5, 2006 I've tried again to get that light out, but it's not having any of it lol! It's not too bad tbh, I can leave the bottom bit of the ashtray in there, and still take the panel off. edit: w00t 2000th post Quote Link to comment Share on other sites More sharing options...
Jive Posted February 6, 2006 Share Posted February 6, 2006 its available from any good motor factors and two cans wil be more than enough:) Ah ha . . cheers Mr Loopy Quote Link to comment Share on other sites More sharing options...
chilli Posted February 6, 2006 Share Posted February 6, 2006 ahhhh excellent thread as I was only thinking (day dreaming whilst stuck in a meeting at work lol) that it would be good to redo my dash sometime Just got to decide on the best colour, silver is an option, so is black but I'm kinda thinking dark metallic grey might be nice. also, is it easy / worth it to convert to a face lift dash? mine is just slightly pre face-lift and some extra dials might be nice... Quote Link to comment Share on other sites More sharing options...
jackso11 Posted February 6, 2006 Share Posted February 6, 2006 Thing is when going to a facelift dash, the ODO is no longer digital. So you would have to 'clock' a face lift dial set to get the same reading. IMO Toyota made a mistake changing from digital to the wheel type. Seems like going backwards to me. Quote Link to comment Share on other sites More sharing options...
