Bad news about my car.
Gamer
  • Replies 59
Thanks guys...
The latest on the cause is that it was piston failure leading to crankshaft pressure, leading to oil spray over the manifold/turbo.
Was it the front oil seal that blew, or is it impossible to tell now? I had same problem on my old engine, back pressure into crank case blew front oil seal 3 times, that seems to always be the weak point that goes first.
I am not sure Nic, I will know more in a few days.
just caught up with this post really gutted for you joe stunning car did you ever do the shoot for jap performance??
anything i can do mate please give me a shout
Yes Wayne, luckily I did get the feature work done for JP mag. I called the bloke at the mag today and let him know what happened. He was just about to send me the print to have a read over for final approval too, he might need to add a few words now. :badidea:
Life goes on and I am feeling much better now knowing that I will be replacing her with a real fine example of a Supra.
Thanks again everyone for the kind words, it does mean a lot.
Sorry to hear. I nearly had this happen, caught it just in time, taught me to use metal oil pipes only on my turbos. Enjoy the Supra!.
It was not an oil line as I had just guessed it was that, all I knew is it was an oil related fire. Apparently at least one piston failed which provided sufficient crankcase pressure to overcome the breather system, which in turn sprayed oil over a glowing hot turbo and manifold with catastrophic consequences.
Thanks again for the commiserations everyone. I am feeling happy yet sad at the same time.
