Bmw M5
ADD
  • Replies 57
Posted Images
my freind has a 2000(w) m5 400bhp which i drive a lot its bloody fast with loads of low down power but judging by how my uk tt catback car goes now im sure ill beat it at bpu+im reaching similar speeds on certain stretches of road at present. as for the new one imo noo way that looks really mad
Guest Terry S
If the M5 is a genuine 200mph car then the T61 will be hammered.
Doubt that very much, a t61 car will not only be lighter with similar bhp, but have more torque. They have the gearing for 200mph though.
Me 4 BTW.
New Rs4 very similar specs but down on power slightly
2006 Audi RS4 Year 2006
Engine Location Front
Drive Type- 4WD
Weight- 3415 lbs | 1549 kg
Performance
0-60 mph- 4.7 seconds.
Top Speed- 250 km/h | 155.4 mph (limited)
Engine
Engine Configuration- V
Cylinders- 8
Aspiration/Induction- Normal
Displacement- 4163.00 cc | 254 cu in. | 4.2 L.
Horsepower- 420.00 BHP (309.1 KW) @ 8250.00 RPM
Torque- 430.00 NM (317 Ft-Lbs) @ 5500.00 RPM
HP to Weight Ratio- 8.1 LB / HP (Vehicles with similar ratio)
HP / Liter- 100.0 BHP / Liter
Redline- 8250
Bore- 84.50 mm | 3.3 in.
Stroke- 92.80 mm | 3.7 in.
Fuel Feed- FSI Direct Injection
Standard Transmission
Gears- 6
Transmission- Manual
Final Drive -3.89:1
Optional Transmission
Gears- 6
Transmission- Tiptronic
Here are the data
.........................0-400m---------0-1000m----------v max
Supra stock........14.089 (103)---24.868 (139)-------179
330 bhp
Supra bpu..........13.864 (113)---24.103 (147)------189
388 bhp
t67ish single........13.379 (123)---22.715 (162)-------192 (limiter)...210 (longer gearing)
521bhp
m5......................12.545 (118)---22.285 (155)-------201
off to work now...
Problems with the M5 are:
1. Its ugly
2. Its a BMW
3. Its not a 200mph car. Much like the J-spec they've detuned lots of it cos it will only do 155mph (limiter) so smaller brakes, aerodynamic issues, downgraded tyres & suspension components etc.
4. I've heard theyare having gearbox "issues" with them so much like a NOS'ed up corsa, they will do 0-60.....
..once.
