rltc problem
jayssupra
Terminator, Just as a work around AOL. You could try Zipping the file using WinZip... As you could find the email servers and software is trying to read the dat files thinking it is something else. dat files commonly being used on computers of course.
When I send some one a dat I alter certain perameters according to individual need. I also keep their dat on file so I have them for reference and back up for members. I have over 150 dats now. It is very easy to alter a few things in error and render RL usless and the car performance suffer. You still need a base dat when you have the digi adjuster. The likelyhood of screwups with the new adjuster is very high, I can just imagine a curious passenger having a little play while you are out of the car. I never got round to fitting mine as the old black knob does a good job, I know the visuals are pretty but not necessary.
RL is not didficult to set up once you know what you are doing, but for many they like the security of having a file produced for them from someone with a little experience;) when they first get started with RL.
Termy i have had your dat for ages now running bpu (and mighty fine to) but i have had a couple of moments since gone single, are there parameters that could be tweaked for a single set up or am i just exceeding the capabiltys of the system, the moment i got a bit of a slide was on dryish road on wet setting when i did a full throttle shift up mid corner, hmmmm i may have just answered my own question there as that does sound a bit dum in reflection, what do you think
