Fuel pump change - some pics
letmeshowyou
First of all a big thankyou to Terry for getting a fuel pump to Phoenix for me to collect yesterday. Much appreciated!
Having read Matt Harwood's instructions figured it would be pretty straightforward :
http://www.mkivsupra.net/vbb/showthread.php?t=45647
but couldnt find many pics on the subject so here's mine (apologies if someone has already done this!!):
Fuel tank access cover removal:
Cover removed:
Pipe's undone and connector removed (I started the engine with the connector removed to depressurize the lines (as recommended on the walbro instructions!) - saved me getting covered in fuel!:
Undoing the jubilee clip and sealing ring were pretty straightforward with the aid of a mallet and a softish piece of wood, then the pump was removed:
An empty hole!:
Old pump in the assembly:
New pump in the assembly:
Whole job took little over an hour (Great instructions Matt) - would have been quicker if the phone hadn't rang too! Took more time to change the spark plugs as it turned out...
Adi.
(slowly edging towards BPU!)
I mate thanks for these pictures very useful just had a bit of a way up as I’ve bought a HKS pump and was going to install it but just a few quick questions, what did you use to insulate the wires? Were did you get your black connectors from that go onto the pump?
Cheers mate
not difficult to do but just a bigger fuk up if anything goes wrong during or after the fitting if you get what I mean.
It did take me longer to do the plugs tbh, the two plugs nearest to the windscreen is the hardest to get to and if a screw drop into the plug hole then :) omg
China
  letmeshowyou said:
mine came with all I needed in the box - did yours not come with the connector?
No it came on its own with no connectors, not sure if i'm going to have to get it fitted somewhere not really sure about having to get make shift connectors in a fuel tank!
Guest Terry S
it should come with a fitting kit?
Guest Terry S
  chilli said:
well mine didn't either lol, just some pipe and clips, some wire and a connector, nothing to join them with though...
LOL thats what they call a fitting kit.
  letmeshowyou said:
i suppose there's always the slight possibility that the HKS pump uses the same connector as the standard one also?
That's what i was told when i bought it but when i striped out the old one its totally different from the stock one see pic
ahh ok lol, sorry yes it came with that fitting kit but not with the electrical connectors some people seem to have got also... hence the need to solder it up. I'm happy with mine so I'm not bothered, just seems there are two types of fitting kit maybe? one with electrical connectors.
  chilli said:
stagger the joints, solder + heatshrink = good job :)
Proper fuel resistant heat shrink?
I was talking with CW the other day about this. The normal stuff won't last. The right stuff is ££££'s and can only be bought in large qty.
Finally sorted it :) it turns out that the HKS pump is made by the same company that produces the Skyline pump. So after speaking to CW (big thanks btw) I went to dbmotorsport and they gave me a skyline fuel pump connector as you can see from the pic. It covers the positive terminal and leaves the negative exposed.
Must say what a place dbmotorsport is! wow they had 4 R34 v-spec's being modded what a sight with 19" split rims, I think I have just chosen my next car!
  • 1 year later...
