gaijin Posted January 27, 2006 Share Posted January 27, 2006 Finally bought a Supra(from Whifbitz)Picking it up next week,its a cracker!It has the usual rear fog bolted on underneath.Does anyone know how to intergrate it into the light cluster?I am very new to supras so i am on a learning curve.Appreciate any help;thanks. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted January 27, 2006 Share Posted January 27, 2006 Finally bought a Supra(from Whifbitz)Picking it up next week,its a cracker!It has the usual rear fog bolted on underneath.Does anyone know how to intergrate it into the light cluster?I am very new to supras so i am on a learning curve.Appreciate any help;thanks. when i got my soop it did not have either and had somehow passed its mot twice>??????????????? anyway i got a switch and i sacraficed one of the reversing lights and put in a bright red one and wired it to a relay switch underneath my steering wheel so i never drilled in the dash, i have heard a few people saying there is double bulbs half read and half reversing but i have never seen one i just went for the easiest option Quote Link to comment Share on other sites More sharing options...
superstar dj Posted January 27, 2006 Share Posted January 27, 2006 the other option is to loose two of the four brake lights and have two fog lights,only thing is you get a light on your dash to tell you that there is a rear lamp busted.....solution-remove the dash lamp bulb! Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted January 27, 2006 Share Posted January 27, 2006 the other option is to loose two of the four brake lights and have two fog lights,only thing is you get a light on your dash to tell you that there is a rear lamp busted.....solution-remove the dash lamp bulb! There is a solution which involves some resistors, this means you can keep the rear bulb fail indicator. Search for Pete Betts Fog Conversion. I had a thread a while back which included some photos too. Good Luck - really tidies the rear end up Mike Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted January 27, 2006 Share Posted January 27, 2006 Fog Light conversioin improved wiring here you go Mike Quote Link to comment Share on other sites More sharing options...
Irvy Posted January 27, 2006 Share Posted January 27, 2006 Fog Light conversioin improved wiring here you go Mike this is the one i had done...no problems, no fault light, and no loss of the double brake lights unless you switch the fogs on Quote Link to comment Share on other sites More sharing options...
gaijin Posted January 27, 2006 Author Share Posted January 27, 2006 Thanks for your replys,much appreciated.Will have a good look.It has to be worth the trouble as the Supra is such superb motor.look forward to many visits,but hopefully not on the tech section! Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 30, 2006 Share Posted January 30, 2006 my car seems to have the extra brake light (row of leds in the centre) changed into the fog light. dunno how it was done but pretty clever stuff.... Quote Link to comment Share on other sites More sharing options...
