DaveMassie Posted January 27, 2006 Share Posted January 27, 2006 Hi people, Had a slight problem with my 94 N/A a few days ago, the temp guage went right up to the redline, then suddenly dropped down to its normal half way position. Thinking the rad had gone I chucked some rad weld in ( I know nasty stuff, but urgently needed to get back home) and it behaved itself all the way back to London from Norwich. I’ve not used the car since, but my girlfriend has done for a couple of short trips and it didn’t missbehave until she used it again this morning for work, and she said it did the same thing, temp went right up and then dropped back down to normal. What would cause this, a sticky thermostat, or is the rad fubar’d? Any help or opinions gratefully received. Dave Link to comment Share on other sites More sharing options...
Lucifer Posted January 27, 2006 Share Posted January 27, 2006 Firstly Get that SH** flushed out of there, its awefull stuff and does not do your water system any good at all. {off soap box} Usually specking its the thermostat... well 8/10 times anyway! Link to comment Share on other sites More sharing options...
DaveMassie Posted January 27, 2006 Author Share Posted January 27, 2006 Cheers Lucifer, Will get one ordered later on, hopefully a nice cheap fix... The system will get a good flush out at the w/e. Link to comment Share on other sites More sharing options...
Lucifer Posted January 27, 2006 Share Posted January 27, 2006 Its not a dead cert, but most likley adn a cheap place to start. Link to comment Share on other sites More sharing options...
DaveMassie Posted January 27, 2006 Author Share Posted January 27, 2006 For sure, its a cheap and easy solution to try 1st, any other ideas what else it may be if it isnt the stat? Thanks Dave Link to comment Share on other sites More sharing options...
