Blitz Access ECU + Fault
Supraguy
Wow. Had a nice little suprise today when I went to take a peek at my ECU wiring today. Pulled back the carpet to reveal I had a Blitz Access ECU PC-23710T installed in the car!! Anyone have any stories good or bad about these things? I am wondering if its got anything to do with a couple problems with my car.
#1 Fueling- The car seems to be running very rich. Little bit of light smoke when giving it alot of throttle. (Noticed by Roy on last weekend's London cruise) Is there any way to tone down the fueling on this ECU, or will I have to use my Apexi S-AFC II that is on order to sort it?
#2 Trac off Light Flashing- It was pointed out that it could be a faulty speedo conversion kit, so the speedo kit was removed completely (running in KMH) and the fault still persists. On a cold start, when you first turn on the car the Trac Off light will flash. There will be no MIL, Check Engine, etc.. nothing else lit. This only happens maybe 1 in 10 times. But, the worrying part is the fact that the car will not go in reverse when its flashing. To clear the fault, I have to turn off the engine for a few seconds and it goes away.
It always comes up on cold start up, and never manifests itself when the car has already been up and running. Any ideas??
Little update. JIC took the car in this week to have a go at this under warranty repairs. I've got to admit, I am impressed with their service though. They gave me a "courtesy car" for the time its in the shop! Its nothing spectacular, but its a manual MKIII Turbo. I was quite shocked to find its performance is nothing close to the MKIV TT.
It still goes, but it puts into perspective what a beast the MKIV truely is! Cant wait to get it back, and hopefully without a glitch.
