rob wild Posted January 25, 2006 Share Posted January 25, 2006 Ok got my AVCR EBC installed. Gone through the instruction very carefully but just wanted to check something. I reset the device then went into car setup and set usual 6cyl, 4sp Thr Up. I then went to the main menu and when to [setting A.] and set it to 1.15 and 70 Percent. A graph came up now at this point the instruction said drive the car hard to it got to the boost level. Ok so got onto the road and floor it as soon as the car started boosting (0.2bar) the solenoid starting making like a fast vibrating / popping noise is this normal? does your's make a noise? Any advice would be must appreciated Thanks Link to comment Share on other sites More sharing options...
stt Posted January 25, 2006 Share Posted January 25, 2006 Mine ticks away like nobodies business,I would be able to help further but the car is in my garage which is a good walk from my house otherwise i would be able to tell you more,Mine was set up by a garage in Cardiff though as these are notorious for being a pain in the ass! Link to comment Share on other sites More sharing options...
veilsideTT Posted January 26, 2006 Share Posted January 26, 2006 Get a single turbo and a nice loud exhaust! I cant hear mine anymore! PS, a bitch to set up with twins, Great with a single and the learn gear function is quite impressive when its set up correctly Link to comment Share on other sites More sharing options...
supRo Posted January 26, 2006 Share Posted January 26, 2006 Hi mate, mines doesn't make those noises! Just for your info, my BPU car was setup on a dyno and the gain was set to 52% for 1.2 bar. Obviously all cars are different but it may be worth bearing in mind and try setting the gain to about this level and see if it still makes the noises. Link to comment Share on other sites More sharing options...
rob wild Posted January 26, 2006 Author Share Posted January 26, 2006 Cheers for that guys it sounds like the noises are normal and it very much depends and how and were you mount the solenoid! I'm going to remount it this weekend. When i've got it all set up i.e. the setting A and setting B how easy is it to switch between the to? and then can you go into monitor mode? Only just started using it really! thanks guys Link to comment Share on other sites More sharing options...
fastisnice Posted January 26, 2006 Share Posted January 26, 2006 Thats true, it does depend on where you mount it...Mine used to make a ticking noise until i remount it further away from the cabin Link to comment Share on other sites More sharing options...
TrickTT Posted January 26, 2006 Share Posted January 26, 2006 press the next and prev buttons together for 1 second to toggle between monitor and setting mode Link to comment Share on other sites More sharing options...
veilsideTT Posted January 26, 2006 Share Posted January 26, 2006 press the next and prev buttons together for 1 second to toggle between monitor and setting mode Good man, Didnt know that! Link to comment Share on other sites More sharing options...
rob wild Posted January 26, 2006 Author Share Posted January 26, 2006 Yeah just tried that got it the measure the boost looks really good! bit odd though seemed to be boosting past the set amount may have to play with the duty cycle! Very impressed though seems like a really good piece of kit! Link to comment Share on other sites More sharing options...
veilsideTT Posted January 26, 2006 Share Posted January 26, 2006 You need to start with the duty cycle low and move it up untill you can reasonably hold boost at your desired level. I found it best to put the AVCR in self learn mode after this and the AVCR will learn the cars boost pattern and re adjust itself to hold boost better. You will know when the AVCR has self learned when the duty reads *** Im single and i ran around 51% duty on 1.3bar. Now its self learned it holds better and adjusts its own duty % Then after that you can fiddle with the learn gear feature, as in 1st and 2nd i wasnt hitting the target. You can add or minus duty for each gear if your under/overboosting in a particular gear. Very handy If all else fails Scotty Link to comment Share on other sites More sharing options...
