scooby_doo_do Posted January 24, 2006 Share Posted January 24, 2006 I'm after some free/dirt cheap bits for the camper :-) Need a mp3 head unit of some sort: Some Subs: Some speakers: Amps? (got one of these in the garage but the more the better!) Cables ? I've been keeping an eye on some bits on ebay but they seem to keep getting sniped and people charge a lot on postage :-( Link to comment Share on other sites More sharing options...
GazzaGSi Posted January 24, 2006 Share Posted January 24, 2006 As I was messed around ebay I still have this amp for sale. For full spec go here: http://caraudiosecurity.com/shop/product/products_id/4378.html 2 channel, bridgeable into single (mono) channel amplifier SPECIFICATIONS Power Source Volts = 10.8 - 14.4 Number of Channels = 2 Rated Power @ 14.4V Watts RMS @ 0. 1 % All Channels Driven 4 Ohms = 2 x 50 Rated Power @ 14.4V Watts RMS @ 0. 1 % All Channels Driven 2 Ohms = 2 x 100 Rated Power @ 14.4V Watts RMS @ 0. 1 % All Channels Driven Bridge 4 Ohm = 1 x 200 Typical Power @ 14.4V Watts RMS @ 0. 1 % All Channels Driven 4 Ohms = 2 x 95 Typical Power @ 14.4V Watts RMS @ 0. 1 % All Channels Driven 2 Ohms = 2 x 145 Typical Power @ 14.4V Watts RMS @ 0. 1 % All Channels Driven Bridge 4 Ohm = 1 x 290 Maximum Current Draw = 37 Amps Signal to Noise Ratio 'A' Wtd @ 4 Ohm = > 100 dB THD + Noise @ Rated Output = 0.1% Input Sensitivity = 0.3 - 5 Frequency Response = 20 Hz - 20 KHz Dimensions (mm) = 62 x 200 x 210 FEATURES Tri-mode Operation Gold Plated Terminals/Connectors 4 Volt Preout Compatible Variable High Pass Crossover Variable Low Pass Crossover Fan Output £220 ono Can deliver at abit extra cost - - will be around £6 I would of thought. Link to comment Share on other sites More sharing options...
