HELP Bolts needed for front caliper
mr lover
Just been putting on my new CW brake pads and the previous muppet that changed the brake pads, knackered the top and bottom bolt and the pin/piston that they bolt into, the bolts that release the caliper to change the pads, I hope that makes sense.
Does anybody have any of these or know the part no. as the car is sat outside and i cannot use it, i am happy to pay just need them QUICK.
We got some the other day, are these the parts you need. Assuming yours is J spec.
If so, the part no is - (for the bolt) 90109-08214 @ £1.63 (plus the dreaded) each - takes two days from toyota.
I do not have the part number for the slider, but they are equally quickly available from Toyota.
