Phil Offord Posted April 11, 2002 Share Posted April 11, 2002 I think that i am going to remove my Blitz induction kit, refit the stock air box fitted with a K&N filter, as i am getting fed up with the wet fart/very under powered jet noises that i get when i am pulling away gently (I don't mind the noise when you are going for it). I am thinking of fitting a dump valve, but want one which only dumps pressure when you are driving hard......i.e no wet fart noises under gentle acceleration and gear changes. Can anyone recommend which is the best one for the job? Thanks Phil.O Link to comment Share on other sites More sharing options...
THOR Racing Posted April 11, 2002 Share Posted April 11, 2002 The HKS Sequential BOV has adjustable pressure release. Just turn a nut on the back to increase or decrease the spring pressure an hence BOV release pressure. I then removed the stock BOV. Pete Link to comment Share on other sites More sharing options...
Phil Offord Posted April 11, 2002 Author Share Posted April 11, 2002 Thanks Pete that sounds like just the job! Link to comment Share on other sites More sharing options...
