auto box oil change.
supra matt
  • 3 weeks later...
Some questions
I have had an engine damage and dissambled all parts completly. Take out the engine with the AT Gearbox.
http://f5.putfile.com/6/17905304751-thumb.jpg
I have removed the gearbox and put it in my garage without draining the oil. Only remove the Tranny cooler pipings from the gearbox. Some oil drains after removing but not to much.
After 2 month I go into the garage and found a lot of oil around the gearbox. I don't know If it was drained from the piping mounts or from the converter.
After assembling I've drained the oil out of the pan and fill it with new one. Have read the workshop and there was told I should shift several gears after filling. Did it and see I need to fill more oil.
After checking everything was fine, I did a test drive and now I have following problem:
Normaly I release the brake pedal the car runs slowly. Now I have the problem that the car doesn't run. After I put the throttle the car starts running. Shifting was really fine but what could be the problem that the car doesn't put in the clutch after releasing the brake pedal. (sorry for my bad english. hope anybody knows what I told)
PLEASE HELP
Cheers
Peter
