SOOO WHITE Posted September 7, 2003 Share Posted September 7, 2003 right boys and girls this might sound abit daft but since av no haynes manual to look at where about in the engine do you check the level of oil in ur gear box or is the oil for the whole engine supply that plz help cheers Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 7, 2003 Share Posted September 7, 2003 Moved to technical Is your an auto? If so its right next to the engine oil dipstick. Gaz. Link to comment Share on other sites More sharing options...
SOOO WHITE Posted September 7, 2003 Author Share Posted September 7, 2003 oops soz my bad put in in the wrong forum yep gaz its an auto cheers for the info Link to comment Share on other sites More sharing options...
Paul Laing Posted September 7, 2003 Share Posted September 7, 2003 Anyone know where this is on a NA Manual? Also is this the same oil used in the LSD Link to comment Share on other sites More sharing options...
Alex Posted September 7, 2003 Share Posted September 7, 2003 Originally posted by Paul Laing Anyone know where this is on a NA Manual? Also is this the same oil used in the LSD Take the fill point bolt out the side of the diff or g/box and put your finger inside (oo-er) if the fluid is just below the fill hloe then its full. If it's significantly lower then top it up. Link to comment Share on other sites More sharing options...
