Funny Engine Noise?
Mark Ayling
My description is going to be as technical as the thread title :D
A bit difficult to explain really, but here goes...
When you open the bonnet of a standard Supra and rev the engine, it makes that kind of massive roar/suction noise. Then when you stick a Hiper or something on, you can't hear it as well because of the sound of the exhaust. (with me so far? :p )
Well in the last few days, I've noticed that my engine has started making that sound, but many times louder than the sound of a standard Supra - I can hear it over the Hiper, and even on the motorway! I actually really like the noise, it sounds really meaty, like a truck engine or something, but clearly its not normal as its only started doing it recently.
I hope someone understands what I'm on about, I wasn't sure how else to explain it!
Oh, by the way, the car is driving fine - no boost (or other) problems that I'm aware of.
Thanks in advance!
Right, I've just been out and had a look. I can't see/detect and sort of leak, all the fixings are fine and nothing's off/loose.
The fan is on constantly though, and it does sound like the fan that's making the noise. So am I right in thinking that the fan should only come on at a certain temperature, and the fact that mine is on constantly suggests a dodgy sensor/switch or something?
There is no switch or sensor on the fan it is a viscous coupled unit. They can and do stop working and can stay on all the time. I normal conditions the fan will rotate but it may be that yours has gone. I had one go on a Cossie sounded like a turbine quite cool really.
I would not suggest trying to stop it with your hand though, unless you dislike one or two of your fingers enough to drop them in the under tray.
OK I'm not going to claim I understand that (especially having just got back after drinking since 3.00pm! :p ), but are you saying that I may need a whole new fan then? Or could something else being faulty cause it?
BTW I wasn't going to try and stop the fan with my hand! :eek: :looney:
Originally posted by 400BHP
With the engine off, and cold, see if you can spin the fan easily, if not, then either your viscous coupling is U/S or its been modified to be on all the time, i think the latter is doubtful.
Yep, I tried that yesterday - the fan didn't spin freely.
So my viscous coupling is stuffed - does that entail a whole new fan assembly or just part of it?
TIA
The fan and fluid coupling are one unit, this unbolts from the pulley, you may need a cranked spanner to undo the nut.
Left hand thread.
Nice one, cheers for that :thumbs:
Just spoke to the garage and the fan's 140-something quid! :eek: Still, the labour will be next to nothing as its a very simple job.
Thanks again chaps :cool:
  • 3 weeks later...
