dark stranger Posted January 22, 2006 Share Posted January 22, 2006 is fitting a starter motor something i could do on my drive.....or is it a nightmare...anyone.....is there a certain way it has to be fitted....appreciate any advice...im getting withdrawal symptoms:drown: Link to comment Share on other sites More sharing options...
merckx Posted January 22, 2006 Share Posted January 22, 2006 You'll need access to the underneath of the car. Disconnect battery!!!!!! Decent socket set with long!!!! extension bar. Link to comment Share on other sites More sharing options...
suprasport Posted January 22, 2006 Share Posted January 22, 2006 technically very easy, physically, its a nightmare. i was laid on my back for 4 hours taking out 2 bolts, as merckx said you will need a selection of extension bars Link to comment Share on other sites More sharing options...
Jake Posted January 22, 2006 Share Posted January 22, 2006 As Merckx said, as long as you can get the car up on axle stands or ramps it's quite straightforward to change the starter. FOUR HOURS!? Did you fall asleep? Link to comment Share on other sites More sharing options...
Pete Posted January 22, 2006 Share Posted January 22, 2006 I believe the fitting instructions are in the member download area somewhere. Link to comment Share on other sites More sharing options...
dark stranger Posted January 22, 2006 Author Share Posted January 22, 2006 cheers guys....hopefully the pretty piece of metal in my drive will move again tomorrow:) Link to comment Share on other sites More sharing options...
Prof. Monkey Posted January 22, 2006 Share Posted January 22, 2006 Nasty job! Good luck buddy! Link to comment Share on other sites More sharing options...
penguin Posted January 22, 2006 Share Posted January 22, 2006 pretty easy if you have the right tools........... a VERY long extension bar is essential... took me over 6 hours to get the top bolt off Link to comment Share on other sites More sharing options...
dark stranger Posted January 22, 2006 Author Share Posted January 22, 2006 looks like i better get a mattress under there then.....great Link to comment Share on other sites More sharing options...
TrickTT Posted January 23, 2006 Share Posted January 23, 2006 pretty easy if you have the right tools........... a VERY long extension bar is essential... took me over 6 hours to get the top bolt off Good lord you must get through a lot of tea. Jacked mine up, removed and refurbished the starter, refitted it and put the whole lot back on the floor in about 1 hour. Easy job!!! Link to comment Share on other sites More sharing options...
Lewis Posted January 23, 2006 Share Posted January 23, 2006 easy when you know how, if not - pita Link to comment Share on other sites More sharing options...
