Paul R Posted September 6, 2003 Share Posted September 6, 2003 Hi, Just got a cheap boost guage to fit to my car and I didnt notice before but I'm not sure what it's reading in?? it says LB/(triangle) at the bottom of the guage. (Triangle) being a pic of a triangle. Would this mean PSI?? Also where do I plumb it into?? can someone send me a pic of a engine bay with the appropriate place circled?? Cheers, Paul. Link to comment Share on other sites More sharing options...
Steve W Posted September 6, 2003 Share Posted September 6, 2003 should be Pounds per Square Inch (pressure!, psi ) might read 30-0-30 or 15-0-30 or so ? ? (VERY roughly 2-0-2 or 1-0-2 BAR) Link to comment Share on other sites More sharing options...
Steve W Posted September 6, 2003 Share Posted September 6, 2003 most plumbed in with a TEE on Inlet Manifold....... Link to comment Share on other sites More sharing options...
Steve W Posted September 6, 2003 Share Posted September 6, 2003 this is on mine.... it's been un'plugged' just before the manifold was removed.......... (same place as previous pic') Link to comment Share on other sites More sharing options...
Steve W Posted September 6, 2003 Share Posted September 6, 2003 . Link to comment Share on other sites More sharing options...
Steve W Posted September 6, 2003 Share Posted September 6, 2003 .. Link to comment Share on other sites More sharing options...
Steve Cargill Posted September 7, 2003 Share Posted September 7, 2003 lbs is the abbreviation for pounds (weight). Technically the guage should say lbs psi (pounds per square inch). Mine I think is -30 to +30. Link to comment Share on other sites More sharing options...
Steve W Posted September 7, 2003 Share Posted September 7, 2003 technically it shouldn't say Pounds or Inches as they're both out-of-date measurements ! ! (over here anyhow!) You're NOT still measuring yer speed in MILES per HOUR, are you ? ? Link to comment Share on other sites More sharing options...
Paul R Posted September 7, 2003 Author Share Posted September 7, 2003 Thanks guys, I'm going to install it this morning. I havent got a pod yet though so the guage is gonna just rest on the dashboard! Anyone know of a suitable cheap one that I can mount on my pillar? A single one would be better as I'm not bothered about any other guages. I dont want to replace my clock either as I find it handy! Paul. Link to comment Share on other sites More sharing options...
Steve W Posted September 7, 2003 Share Posted September 7, 2003 WELL, yeah I used to find it handy....... before I started using Full Wack ! ! ! No longer measure me 1/4 in minutes ! ! " Time is no LONGER relative..... when drivin' a SOOP ! ! " Link to comment Share on other sites More sharing options...
400BHP Posted September 7, 2003 Share Posted September 7, 2003 You may find the boost gauge has mm/hg on it, this is a vacuum scale that is measured in millimeters of mercury. Link to comment Share on other sites More sharing options...
Steve W Posted September 7, 2003 Share Posted September 7, 2003 normally the mmHg is on the negative side 'cos your supposed to measure PRESSURE in BAR/psi and VACUUM in mmHg ? Link to comment Share on other sites More sharing options...
Paul R Posted September 7, 2003 Author Share Posted September 7, 2003 Got the gauge fitted, no problem. I'm only getting 10PSI(0.7 bar) though and that doesnt sound a lto to me? Shouldnt I be hetting 12PSI(0.8 bar)?? I'll post another thread on this... "Only hitting 10PSI" Cheers, Paul. Link to comment Share on other sites More sharing options...
400BHP Posted September 8, 2003 Share Posted September 8, 2003 Originally posted by Steve W normally the mmHg is on the negative side 'cos your supposed to measure PRESSURE in BAR/psi and VACUUM in mmHg ? Yep you are correct, positive pressure in lb/in2 and negative pressure in mm/hg Link to comment Share on other sites More sharing options...
