oilman Posted February 28, 2012 Share Posted February 28, 2012 The Redline GL5 is a good one for the diff. In the engine, go for a 10w-50 to stay on the safe side. http://www.opieoils.co.uk/c-659-10w-50.aspx The Nanodrive CFS is, on paper, the best oil available, but the Pro S and CFS are both really good oils, so all are good choices for your car. Cheers Tim Link to comment Share on other sites More sharing options...
mellonman Posted April 5, 2012 Share Posted April 5, 2012 Hi could you please clear something up for me its about dextron ii,iii,iv,v i have read that the they back replace each other so we could put dextron v in the auto box and would be the same as the ii (the oil used over 15 years ago). is that the case? Link to comment Share on other sites More sharing options...
oilman Posted April 5, 2012 Share Posted April 5, 2012 Yes and no. According to my info, the pre-1993 Supras can use a Dexron II, from 2003 onwards they need a Toyota Type 4 ATF. http://www.opieoils.co.uk/p-60163-fuchs-titan-atf-4400-automatic-transmission-fluid-for-japanese-cars.aspx http://www.opieoils.co.uk/p-1052-amsoil-synthetic-automatic-transmission-fluid-atf.aspx http://www.opieoils.co.uk/p-60226-millers-oils-millermatic-atf-sp-iii.aspx Those are all meet the Type 4 spec, so are fine to use, but they are all also Dexron III or higher approved, so are fine in earlier Supras. The only real problem in using a higher spec Dexron oil where a II or III and a Dexron VI is used. Usually it's okay, but Dexron VI oils are a little thinner than II or III. Cheers Tim Link to comment Share on other sites More sharing options...
Guest Budz86 Posted April 11, 2012 Share Posted April 11, 2012 Bumped for Robski Link to comment Share on other sites More sharing options...
firin Supra Posted May 12, 2012 Share Posted May 12, 2012 Hi im new to the oils and what grades they are and what we should use but could sumone help me. Iv got a 94 uk supra tt with 103k on the clock bpu and only drive it on sundays now its due for a oil change but iv always used millers 10w 40 i was told that is the best. Now iv been in to a local part place where i normally get my oil from and they have suggested that i use carlube 10w 40! i change the engine oil every 4k miles and the oil filter aswell so they question is is that ok? The guy also explaind to me and said if your changing your oil that frequently your better with the carlube and that you would be wasting your money with the rest because its just as good. Finally the last question is what ngk spark plugs are recommended for bpu? cheers guys love the hard work you guys are putting in! Link to comment Share on other sites More sharing options...
oilman Posted May 14, 2012 Share Posted May 14, 2012 He sells the Carlube, of course it's the best. I guess I'm biased towards higher end oils, but they do give the best protection. I guess the oil they are recommending is a 10w-40 semi and that is a pretty basic choice, a 5w-40 full synthetic is a better choice, even if it's not one of the top end ones, something like the Fuchs Supersyn is an upgrade over the Carlube without breaking the bank. I'd use these plugs http://www.opieoils.co.uk/p-63603-ngk-spark-plug-bkr7eix-opie-ref-2667.aspx Cheers Tim Link to comment Share on other sites More sharing options...
neil tt Posted May 16, 2012 Share Posted May 16, 2012 Just trying to find out which is the correct oil for the A343E gearbox, I have already got Dextron lV, but now been told should be dextron ll, or does it matter, many thanks Link to comment Share on other sites More sharing options...
oilman Posted May 16, 2012 Share Posted May 16, 2012 According to my data, you need an oil that meets the Toyota Type II or higher spec. I would go for either the Amsoil ATF, Motul Multi ATF, Fuchs ATF4400 or Millers Millermatic ATF SPIII. http://www.opieoils.co.uk/c-442-atfs.aspx Cheers Tim Link to comment Share on other sites More sharing options...
neil tt Posted May 16, 2012 Share Posted May 16, 2012 Sorry but would lV be okay, because I already have this, sorry I didn't know I couls use anything else but Dextron Link to comment Share on other sites More sharing options...
oilman Posted May 16, 2012 Share Posted May 16, 2012 Probably, but unless it also meets the T-II/III/IV spec, I can't 100% guarantee it's correct. Cheers Tim Link to comment Share on other sites More sharing options...
Marcus GTE Posted May 16, 2012 Share Posted May 16, 2012 According to my data, you need an oil that meets the Toyota Type II or higher spec. I would go for either the Amsoil ATF, Motul Multi ATF, Fuchs ATF4400 or Millers Millermatic ATF SPIII. http://www.opieoils.co.uk/c-442-atfs.aspx Cheers Tim Hi Tim, I bought some oil from your website a few weeks ago and for the transmission for my auto Ive got 2l of fuchs Titan ATF 4400 Its the first time changing it and I'm wondering if it will be fine to mix with what ever is in there at the moment? I assume it's the toyotas own stuff. Cheers Marcus Link to comment Share on other sites More sharing options...
oilman Posted May 16, 2012 Share Posted May 16, 2012 Hi Marcus It will mix fine with the fluid that's in there, unless someone has put in something really odd already. Cheers Tim Link to comment Share on other sites More sharing options...
Marcus GTE Posted May 16, 2012 Share Posted May 16, 2012 Great, cheers Tim Link to comment Share on other sites More sharing options...
Kaan W Posted November 1, 2012 Share Posted November 1, 2012 Does anyone know if Toyota type IV transmission fluid is suitable for a built auto box? If not what fluid is best to use? Link to comment Share on other sites More sharing options...
Alex Posted November 1, 2012 Author Share Posted November 1, 2012 The box builder should recommend an oil. Link to comment Share on other sites More sharing options...
Kaan W Posted November 1, 2012 Share Posted November 1, 2012 The box builder should recommend an oil. Ok. I just thought if anyone else is running a built transmission that they could reccomend me some oil. Link to comment Share on other sites More sharing options...
Kaan W Posted November 5, 2012 Share Posted November 5, 2012 Ok. I just thought if anyone else is running a built transmission that they could reccomend me some oil. Anyone? Link to comment Share on other sites More sharing options...
Alex Posted November 5, 2012 Author Share Posted November 5, 2012 The Fuchs Titan 4400 stuff will do the job. e-mail opie oils if you want their opinion as they are the specialists. Link to comment Share on other sites More sharing options...
Kaan W Posted November 5, 2012 Share Posted November 5, 2012 The Fuchs Titan 4400 stuff will do the job. e-mail opie oils if you want their opinion as they are the specialists. Ok will do, thanks! Link to comment Share on other sites More sharing options...
Kaan W Posted November 6, 2012 Share Posted November 6, 2012 Ok so ive been told to use Toyota Type IV transmission fluid but I hear that its quite hard to get hold of as its discontinued. Does anyone know the equivelent of this oil that I can buy locally? Link to comment Share on other sites More sharing options...
dan294 Posted November 6, 2012 Share Posted November 6, 2012 The Fuchs Titan 4400 stuff will do the job. e-mail opie oils if you want their opinion as they are the specialists. ^^This mate. I use this in my autobox, its the equivalent to the Toyota stuff. get it from Opie, it's not dear, but bear in mind you'll need a bit extra for the gearbox coolers you've got. Link to comment Share on other sites More sharing options...
oilman Posted November 6, 2012 Share Posted November 6, 2012 We've got the Amsoil ATF, Millers SPIII and Fuchs ATF4400 that you can use instead of the Type IV fluid. http://www.opieoils.co.uk/c-1432-atfs-automatic-transmission-fluid.aspx Cheers Tim Link to comment Share on other sites More sharing options...
Kaan W Posted November 6, 2012 Share Posted November 6, 2012 Cheers guys i'll probably need about 8L i'll have a look now, thanks Link to comment Share on other sites More sharing options...
dan294 Posted November 6, 2012 Share Posted November 6, 2012 Its 10 litres for a full flush I think, so if the box is empty you'll need that plus extra for the gearbox coolers. I needed an extra litre or litre and a half when I had the quick 2 litre change done, including 1x SRD cooler to fill. Link to comment Share on other sites More sharing options...
Kaan W Posted November 6, 2012 Share Posted November 6, 2012 Its 10 litres for a full flush I think, so if the box is empty you'll need that plus extra for the gearbox coolers. I needed an extra litre or litre and a half when I had the quick 2 litre change done, including 1x SRD cooler to fill. Yeah thats what I was thinking but my new box already has some new oil in it as it leaked all over me when I carried it accross my living room... 8L should do I reckon. Link to comment Share on other sites More sharing options...
