FAQ: Oil, Fluid, Interval, Capacity, Steering, Brake, Coolant, Diff, Engine.
Alex
Well the redline shockproof is quite different, but if you are using the likes of the Motul Gear300 75w-90 then I would not have said it was any better, just different. Shock proof is very good in straight cut and problematic gearboxes.
Cheers
Guy
  • Replies 317
Posted Images
  • 6 months later...
Just looking at your offers and wanted to know which would be best suited to my car:
Fuchs Titan Race Pro S 5w/40 or Pro S 10W/50!?
BPU VVTi 2JZ GTE
I was always recommended 10w/50 for BPU and I've always used the pro-s stuff, even when it was silkolene.
Has been great for me. I doubt you will go far wrong with either though.
Hi
I would use a 5w-40 synthetic in the engine.
http://www.opieoils.co.uk/c-656-5w-40.aspx
Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS, Motul 300V, Redline and Gulf Competition. The Motul 8100 X-Cess, Millers XFS, Fuchs Supersyn, Shell Helix and Mobil Super 3000 are good, cheaper alternatives.
You need a 75w-90 for the gearbox and here are the ones we have.
http://www.opieoils.co.uk/c-673-75w-90.aspx
If you want to go for the best, the Millers CRX 75w-90 NT, Gulf Competition, Motul Gear 300, Redline MT90 and Millers TRX are ideal for the gearbox. The Castrol Universal, Motul Motylgear and Fuchs Gear Syn are all decent alternatives.
Cheers
Tim
  • 1 month later...
What would be a good choice for an NA-T in the oil department ?
Hi
I would use a 5w-40 synthetic and you will find those through the link below.
Out of those, the best ones are the Fuchs/Silkolene Pro S, Motul 300V, Redline and Gulf Competition. The Motul 8100 X-Cess, Millers XFS, Shell Helix, Fuchs Supersyn and Mobil Super 3000 are good, cheaper alternatives.
As a budget choice, a 10w-40 will be fine and I would either go for the Fuchs XTR, Millers XSS or Motul 6100
http://www.opieoils.co.uk/c-657-10w-40.aspx
Cheers
Tim
The normal Gear 300 will be fine and so would the Redline 75w-90 GL5.
Gear oils are rated on a different scale to engine oils to try to avoid confusion, but a 75w-90 gear oil is roughly the same as a 10w-40 engine oil in viscosity terms.
Cheers
Tim
