FAQ: Oil, Fluid, Interval, Capacity, Steering, Brake, Coolant, Diff, Engine.
Alex
  • Replies 317
Posted Images
  • 4 months later...
When I replaced my clutch I used Motul Multi ATF 'I think' as recomended from you. When I replaced the oil I noticed that it was much thiner then the oil that was already in the gear box. The gears feel very different now and the gears feel lighter.
The oil may feel thinner because it is fresh/unused oil. Your gears would feel a good bit better after getting rid of old gungy oil :)
  • 1 month later...
Hey,
Im look at changing various oils, i have some Silkoline Pros 5W 40 that had for my DC5, form what i gather this will be ok for the engine? and for the gearbox Motul Multi ATF (http://www.opieoils.co.uk/p-906-motul-multi-atf-fluid-for-automatic-transmissions.aspx) The only one im a bit unsure of is the rear diff oil.. i have a 1996 TT Manual
Cheers
D
Hi
Pro S 5w-40 is ideal for the engine, the Motul Multi ATF is a good choice if it's go the 6 speed box. The diff needs a 75w-90, something like the Redline 75w-90 GL5, Fuchs Syn 5, Motul Gear 300 and Millers CFS NT would be ideal.
http://www.opieoils.co.uk/c-673-75w-90.aspx
Cheers
Tim
Cheers, and yup its the 6 speed box.
I'll order on Monday :)
Just been looking at all the different types and adviseries on the section, i may sound like a noob here but how come on a 6 speed manual it uses automatic transmition fluid? and on the power steering sectio also came up with types for automatics??
Cheers
D
D
Edited by DuaneT.Turbo
Queston... (see edit history)
Cheers
D
D
Hi
Thanks for the order.
ATFs are thin gear oils, used in a lot of manual gearboxes (Getrag 6 speed in Supras, Skylines etc, BMWs, Fords, and others that I can't remember right now). In most cars, an ATF is the requirement for power steering.
Cheers
Tim
Hi
Cheers
Tim
Cheers, Just needed to know i was ordeing ok.. any aditional offer code i need :D
Looks like the Silkolene SILKTRAN SYN 5 75W-90 Fully Synthetic Gear Oil suggested for use in a LSD has recently been re-branded as Fuchs Titan Race Syn 5 75w-90.
I thought that all silkolene was getting rebranded to fuchs.
  • 2 months later...
  • 1 month later...
Hi guys would this Diff Oil be good for the LSD on a 6 Speed?
Klick Castrol recommends the Castrol SAF-XJ 75W-140 and this one is the replacement for it so i recon it should be ok with this?
You only need a good 75w-90 in the 6 speed diff :)
