Brazil Posted July 14, 2010 Share Posted July 14, 2010 (edited) It's spot on for the diff, but no good for the 6 speed box. If you want an oil for that use the Amsoil ATF, Fuchs ATF4400 or Motul Multi ATF. http://www.opieoils.co.uk/c-442-atfs.aspx Cheers Tim Hi, I want to put an order with you guys, the only fluid that I am still not sure about is for the V160 manual gearbox what do you recomend? Differential Oil: 2lt of 75w90 - Silkolene Syn 5 Engine Oil: 5lt Pro S 10w-50 / Silkolene PRO S Brake Fluid: 2lt of Motul RBF660 NGK Plugs: NGK 6097 Do you sell oil filters? I will take 1 of them too. I would like to order this within the next few days so it will be home by the time I arrive. I have a facelift VVTI TT6 Basic Performance Upgrade The BPU upgrades allow the engine to produce more power by raising the boost pressure the turbos produce. VVTi Adjusts the intake cam timing. This gives significantly more low end torque, and helps the larger turbo'd car spool earlier. Also am I able to pay via paypal? Many thanks, Edited July 14, 2010 by Brazil (see edit history) Link to comment Share on other sites More sharing options...
oilman Posted July 14, 2010 Share Posted July 14, 2010 Those three oils that I mentioned earlier (Amsoil ATF, Fuchs ATF4400 and Motul Multi ATF) are the ones that we stock that are suitable for the V160 manual gearbox. I know it's a manual and they are ATFs, but many manual gearboxes use ATFs if they require a thin oil. The Amsoil is probably the most popular one in the V160s, but that's only because it's been around longer. The other two both meet the specs of the gearbox and are fine to use. Because of the heavy fees that Paypal charge, we've stopped accepting it as it would mean that we'd have to reduce the discounts that we give. We take all major cards apart from American Express though. Link to comment Share on other sites More sharing options...
Brazil Posted July 14, 2010 Share Posted July 14, 2010 Those three oils that I mentioned earlier (Amsoil ATF, Fuchs ATF4400 and Motul Multi ATF) are the ones that we stock that are suitable for the V160 manual gearbox. I know it's a manual and they are ATFs, but many manual gearboxes use ATFs if they require a thin oil. The Amsoil is probably the most popular one in the V160s, but that's only because it's been around longer. The other two both meet the specs of the gearbox and are fine to use. Because of the heavy fees that Paypal charge, we've stopped accepting it as it would mean that we'd have to reduce the discounts that we give. We take all major cards apart from American Express though. Thank you Oilman what a fantastic service you have..! Grafter hey..! I've managed to get my new card this afternoon so that will be fine to pay by card. Is there a discount code that I can use right now apart from my 10% club discount? You have so many discounts it's hard to keep up..! haha Link to comment Share on other sites More sharing options...
oilman Posted July 15, 2010 Share Posted July 15, 2010 Okay, use TIM10 for an extra 10% off Link to comment Share on other sites More sharing options...
basaez Posted July 15, 2010 Share Posted July 15, 2010 cheers mate today i recive my Amsoil ATF Link to comment Share on other sites More sharing options...
oilman Posted July 16, 2010 Share Posted July 16, 2010 Thanks for letting me know Link to comment Share on other sites More sharing options...
Brazil Posted July 16, 2010 Share Posted July 16, 2010 Okay, use TIM10 for an extra 10% off I've just tried to pay for my order and it said due to the size of the order they could not give me an estimate? What do you recomend? Link to comment Share on other sites More sharing options...
oilman Posted July 19, 2010 Share Posted July 19, 2010 If you let me have your email address, I'll sort that out for you. Link to comment Share on other sites More sharing options...
Brazil Posted July 19, 2010 Share Posted July 19, 2010 If you let me have your email address, I'll sort that out for you. Pm'd Link to comment Share on other sites More sharing options...
BazzaAlpine Posted July 19, 2010 Share Posted July 19, 2010 Just registered on your site oilman and was wondering what is the current best brand of Fully Synthetic 10w40 oil to go for? Also any extra discount code wouldn't go amiss . Am wanting 5ltr to keep the oil topped up but no idea what the hell was in it before now and prob should mention I'm getting the puff off blue smoke on start up so probable have some leaky valve seals so if a different thickness would be better then I'm all ears. Link to comment Share on other sites More sharing options...
oilman Posted July 19, 2010 Share Posted July 19, 2010 A 10w-40 may be best, probably the Millers CFS, Redline or Motul 300V http://www.opieoils.co.uk/c-657-10w-40.aspx Use the code ENGINEOIL for 15% off engine oils Link to comment Share on other sites More sharing options...
BazzaAlpine Posted July 19, 2010 Share Posted July 19, 2010 (edited) Cheers for that. will see about getting some ordered now.....done Edited July 19, 2010 by BazzaAlpine (see edit history) Link to comment Share on other sites More sharing options...
SamuraiFlash Posted August 4, 2010 Share Posted August 4, 2010 Are Shell engine oils any good? Link to comment Share on other sites More sharing options...
oilman Posted August 4, 2010 Share Posted August 4, 2010 They're pretty good for normal use (depending on which one you pick), but there's better for track use. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted August 4, 2010 Share Posted August 4, 2010 They're pretty good for normal use (depending on which one you pick), but there's better for track use. Hi mate, I was looking at the 5w40 Shell Ultra Helix for my NA. I only do short journeys (6-10 mile trips), i wont be going on track days or anything like that. Link to comment Share on other sites More sharing options...
oilman Posted August 4, 2010 Share Posted August 4, 2010 Yes, that will be fine Link to comment Share on other sites More sharing options...
nigelboyne Posted August 4, 2010 Share Posted August 4, 2010 Hi mate, I was looking at the 5w40 Shell Ultra Helix for my NA. I only do short journeys (6-10 mile trips), i wont be going on track days or anything like that. fantastic oil i use this in my accord after 6-10k change its like blood coming out of the sump still has its properties Link to comment Share on other sites More sharing options...
SamuraiFlash Posted August 4, 2010 Share Posted August 4, 2010 fantastic oil i use this in my accord after 6-10k change its like blood coming out of the sump still has its properties Awesome, i will be buying this oil for my next oil change Link to comment Share on other sites More sharing options...
SamuraiFlash Posted August 7, 2010 Share Posted August 7, 2010 Non of my local shell petrol stations sell shell ultra helix in a 5 litre bottle so I'll be going for either motul or mobile 1 instead. Just wanted to know which would be better suited to my short 6-10 mile trips, 5w-30 or 5w40. What's the difference? On the op it mentions that na supra's came out the factory with 5w30 oil. Thanks in advance? Link to comment Share on other sites More sharing options...
Scott Posted August 8, 2010 Share Posted August 8, 2010 5w40 IMO. I'd hold out for an educated answer though Oh, if going with a thin oil replace it regularly..... 6 months... for such short trips If you want a longer lasting oil go with a 10w50... but make sure you warm the car up before doing anything with it. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted August 8, 2010 Share Posted August 8, 2010 Ok Scott I'll go for the a 5w40 oil, thanks for your help Link to comment Share on other sites More sharing options...
oilman Posted August 8, 2010 Share Posted August 8, 2010 5w-40 sounds good to me Cheers Guy Link to comment Share on other sites More sharing options...
supra_bus. Posted August 8, 2010 Share Posted August 8, 2010 i have been putting mobil 1 fully synthetic in my n/a for 3 years since ownership,gets changad every 6 months regardless of mileage.seems a good match to me. Link to comment Share on other sites More sharing options...
Neil-NA Posted August 28, 2010 Share Posted August 28, 2010 Anyone know of a decent oil for the LSD diff? there's so many to choose from and i dont want to end up with something crap. Link to comment Share on other sites More sharing options...
oilman Posted August 28, 2010 Share Posted August 28, 2010 This one is ideal, very good and popular http://www.opieoils.co.uk/p-68901-fuchs-titan-race-syn-5-75w-90-fully-synthetic-gear-oil.aspx Cheers Guy Link to comment Share on other sites More sharing options...
