novak Posted November 23, 2014 Share Posted November 23, 2014 Thank You for all replies Link to comment Share on other sites More sharing options...
jza800 Posted March 16, 2015 Share Posted March 16, 2015 How about oil to 2jzgte twin turbo bpu.. the only Fuchs i can get local is Fuchs Titan 5w40 GT1 C3 4 ltr, is that fine to my engine???? Link to comment Share on other sites More sharing options...
Scott Posted March 16, 2015 Share Posted March 16, 2015 5 is a little thick to be honest, but it depends how cold it gets where you are. Where are you? Can you not get a shipment from Opie Oils? If you're in a cold climate then 5w40 will be just fine. Link to comment Share on other sites More sharing options...
Alex Posted March 16, 2015 Author Share Posted March 16, 2015 0 -> 20 = Thinnest TO Thickest = Low Viscosity TO Higher Viscosity = Short Trips, cold starts, quick oil pressure at cold temps TO good long trip protection with slightly longer warm up times. Link to comment Share on other sites More sharing options...
oilman Posted March 16, 2015 Share Posted March 16, 2015 Hi Generally in a BPU, we'd recommend a 5w-40 and the GT1 is a decent option, but if it gets hard use, the Pro S would be a more appropriate choice. We can send the oil to most places. Cheers Tim Link to comment Share on other sites More sharing options...
jza800 Posted March 16, 2015 Share Posted March 16, 2015 sometimes i get some hard run/use, but not all the time.. how about the castrol edge (fst) turbo diesel or castrol magnatec both on 5w40 ??? i really think it is a big jungle to find the right oil to our engines Link to comment Share on other sites More sharing options...
Alex Posted March 16, 2015 Author Share Posted March 16, 2015 Have you actually READ this thread? Page 1 Post 1 tells you what to buy...if you have no other clue get what's written there. Diesel Oil?? I mean, REALLY? Link to comment Share on other sites More sharing options...
jza800 Posted March 16, 2015 Share Posted March 16, 2015 yes i did, but when i cant get that local, i have to find the alternative to that .... Link to comment Share on other sites More sharing options...
Alex Posted March 16, 2015 Author Share Posted March 16, 2015 Local, being? I order mine from Opie...2 days to ship at most. Link to comment Share on other sites More sharing options...
oilman Posted March 16, 2015 Share Posted March 16, 2015 Hi The Edge and Magnatec 5w-40s will be fine for road use. The diesel bit in the name can be ignored, it's fine for diesel and petrol engines. Cheers Tim Link to comment Share on other sites More sharing options...
Marcus GTE Posted September 1, 2015 Share Posted September 1, 2015 Hi Generally in a BPU, we'd recommend a 5w-40 and the GT1 is a decent option, but if it gets hard use, the Pro S would be a more appropriate choice. We can send the oil to most places. Cheers Tim Tim, I've had several members recommend 10w-50 for bpu instead of the 5w-40. The reasoning being that 5w might run the risk of pushing past seals that might be getting on a bit now. I know the 5w-40 oils once warm are the equivalent of 10w-40 and thicken up, but on start up with the oil not yet at that temp/ thickness is it at risk of pushing past the seals? On a side note, it would be great to get some of the 20% off codes for the 10w-50 versions of the oils that were just on offer there at 5w-40. Cheers Marcus Link to comment Share on other sites More sharing options...
James Posted September 1, 2015 Share Posted September 1, 2015 Tim, I've had several members recommend 10w-50 for bpu instead of the 5w-40. The reasoning being that 5w might run the risk of pushing past seals that might be getting on a bit now. I know the 5w-40 oils once warm are the equivalent of 10w-40 and thicken up, but on start up with the oil not yet at that temp/ thickness is it at risk of pushing past the seals? On a side note, it would be great to get some of the 20% off codes for the 10w-50 versions of the oils that were just on offer there at 5w-40. Cheers Marcus As long as it doesn't occur immediately - I just 12L of the 10W-50 Fuchs Titan Pro S yesterday Link to comment Share on other sites More sharing options...
Marcus GTE Posted September 1, 2015 Share Posted September 1, 2015 As long as it doesn't occur immediately - I just 12L of the 10W-50 Fuchs Titan Pro S yesterday Exact stuff I'm looking at James Link to comment Share on other sites More sharing options...
Scott Posted September 1, 2015 Share Posted September 1, 2015 As long as it doesn't occur immediately - I just 12L of the 10W-50 Fuchs Titan Pro S yesterday That's the oil I've used since my first service, originally Silkolene. Link to comment Share on other sites More sharing options...
Big Mark Posted September 1, 2015 Share Posted September 1, 2015 I put the same oil in mine too. Link to comment Share on other sites More sharing options...
oilman Posted September 1, 2015 Share Posted September 1, 2015 Tim, I've had several members recommend 10w-50 for bpu instead of the 5w-40. The reasoning being that 5w might run the risk of pushing past seals that might be getting on a bit now. I know the 5w-40 oils once warm are the equivalent of 10w-40 and thicken up, but on start up with the oil not yet at that temp/ thickness is it at risk of pushing past the seals? On a side note, it would be great to get some of the 20% off codes for the 10w-50 versions of the oils that were just on offer there at 5w-40. Cheers Marcus Hi Marcus If you've got a BPU and it's using oil due to it getting past the seals, a 10w-50 makes sense, but if it's not using oil, I'd stick with 5w-40. I think there is likely to be an offer on 10w-50s soon, so keep an eye on our offers. Cheers Tim Link to comment Share on other sites More sharing options...
Marcus GTE Posted September 1, 2015 Share Posted September 1, 2015 Hi Marcus If you've got a BPU and it's using oil due to it getting past the seals, a 10w-50 makes sense, but if it's not using oil, I'd stick with 5w-40. I think there is likely to be an offer on 10w-50s soon, so keep an eye on our offers. Cheers Tim Thanks for the advice Tim and good news about the offer. Seems a few folk will appreciate it Link to comment Share on other sites More sharing options...
Silece2k6 Posted January 13, 2016 Share Posted January 13, 2016 What comes for the 6Spd Torsen Diff? Link to comment Share on other sites More sharing options...
oilman Posted January 13, 2016 Share Posted January 13, 2016 Hi The diff needs a 75w-90 GL5 oil. http://www.opieoils.co.uk/c-673-75w-90-mtfs-manual-transmission-fluid.aspx The Fuchs Syn 5, Millers CRX, Red Line 75w-90 GL5, Motul Gear 300 and Gulf Competition are ideal for the diff. The Fuchs Sintopoid, Castrol Syntrax Longlife, Millers TRX, Motul Motylgear, Mobil SHC and Gulf Syngear are also good choices. Cheers Tim Link to comment Share on other sites More sharing options...
black_widow87 Posted April 2, 2016 Share Posted April 2, 2016 Any reason why not to use Fuchs Titan ATF 4000 for my v160? Have seen a couple of guys on here use it in the past. Link to comment Share on other sites More sharing options...
oilman Posted April 4, 2016 Share Posted April 4, 2016 Hi The 4400 is a higher performance oil and meets the required Toyota spec. The 4000 is a decent ATF, but is a normal oil and doesn't meet the Toyota requirements. Cheers Tim Link to comment Share on other sites More sharing options...
black_widow87 Posted April 4, 2016 Share Posted April 4, 2016 Thanks oilman, i'll go with the ATF 4400. Link to comment Share on other sites More sharing options...
Jellybean Posted May 27, 2016 Share Posted May 27, 2016 Think this is New? Fuchs Titan Race Pro R 10W-40 http://www.opieoils.co.uk/p-89823-fuchs-titan-race-pro-r-10w-40-ester-synthetic-race-proven-engine-oil.aspx PRO R 10W-40 Ester synthetic, high performance engine oil providing outstanding protection for highly stressed engines. It is recommended for use in all high output engines where SH or SJ lubricants are specified. TITAN RACE PRO R 10W-40 may be used to advantage in many modified engines in competition applications. All high performance power units running on lead free, low-lead or racing gasolines benefit from the extra protection of TITAN RACE PRO R 10W-40. Test bed and extensive racing experience show significant increases in power output. Recommended for use with the following specifications:API SL, SJ, SH. Link to comment Share on other sites More sharing options...
oilman Posted May 30, 2016 Share Posted May 30, 2016 Hi The Pro R 10w-40 is relatively new, I guess about 6 months old, but I am rubbish with dates. Cheers Tim Link to comment Share on other sites More sharing options...
Scott Posted May 31, 2016 Share Posted May 31, 2016 What are the V160/161 options now? They seem to be running a bit thin. I went with Royal Purple Synchromax but it would be nice to know the alternatives and comparisons Link to comment Share on other sites More sharing options...
