FAQ: Oil, Fluid, Interval, Capacity, Steering, Brake, Coolant, Diff, Engine.
Alex
  • Replies 317
Posted Images
  • 2 weeks later...
Hi
Thanks for the order.
Don't use the Slick 50, Fuchs do state that no oil additives should be mixed with any of their oils. Also, we do not advise the use of any oil additives, other than friction modifiers for LSDs. Here's why.
http://www.opieoils.co.uk/pdfs/tech-articles/Aftermarket-oil-additives.pdf
Cheers
Tim
Hi Tim,
just placed another order for some service fluids, top service as always and Phil was very helpful :thumbs:.
Thanks
opened up my fill bung to have a look at what's in there and its a nice golden colour but arnt ATF oils all red ?
dose this mean its got the wrong oil in ?
Hi
Generally, ATFs are red, but the colour is just a dye, so in theory an oil can be any colour. There are a couple of ATFs that are blue and I'm sure someone mentioned an amber coloured one to me the other day. Or it could be that someone has used the wrong oil.
Cheers
Tim
  • 3 months later...
  • 4 months later...
Hi
I would use a really good 5w-40 synthetic in the engine.
http://www.opieoils.co.uk/c-656-5w-40.aspx
Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS/CFS NT, Motul 300V, Red Line and Gulf Competition. As it's going BPU soon, go for one of those rather than a more basic oil.
Although it's a manual, it needs an ATF in the gearbox and due to the required specs I would go for either the Amsoil ATF, Motul Multi ATF, Fuchs ATF4400, Gulf Multi Vehicle ATF, Castrol ATF Multi Vehicle or Millers Millermatic ATF SPIII. Those are good for the PAS as well.
http://www.opieoils.co.uk/c-442-atfs.aspx
A 75w-90 GL5 is ideal for the diff.
http://www.opieoils.co.uk/c-673-75w-90-mtfs-manual-transmission-fluid.aspx
The Fuchs Syn 5, Millers CRX, Redline 75w-90 GL5, Motul Gear 300 and Gulf Competition are ideal for the diff. The Fuchs Sintopoid, Castrol Syntrax Longlife, Millers TRX, Motul Motylgear, Mobil SHC and Gulf Syngear are also good choices.
The best fluids for the brakes and clutch are the Castrol SRF, Motul RBF660 and Gulf RF1000. The Motul RBF600, Gulf RF800, Millers 300 Plus and Fuchs Pro Race are close to those, but don't have quite as high boiling points. The next step down (in performance terms), but still an upgrade over standard are the Gulf Racing 5.1, Motul DOT 5.1 and Castrol React Performance. Any of the other DOT4 fluids we have are fine to use as a standard choice.
http://www.opieoils.co.uk/c-450-brake-fluid-clutch-fluid.aspx
The best coolants are the Motul Inugel Optimal or Fuchs Pro Cool, but the Fuchs ESK, Millers Alpine, Castrol Radicool and Gulf are all fine as cheaper alternatives.
http://www.opieoils.co.uk/c-458-coolant-antifreeze.aspx
Cheers
Tim
