Tyre question?
si wants supra
doh! yeah, that's what i meant........honest.
in short, why do you want to make the aspect ratio higher?
am pretty sure they'd fit mate but would make the whole rolling radius of the wheel bigger than it should be.....don't want your fronts to be bigger than your rears!
I do have bigger tyres on the back (aspect ratio) think they are a 45 on the back but was a little worried, about when having the car on a full lock turn or underbraking when the nose dips think i'll give them a go cheers for the quick replys
Si
The 'aspect' ratio= the % of the tyres width, the reason the % is different front and rear is that the front 'turns' so there is a need to have a narrower tyre on the front with a higher 'ratio' than the rear so the circumference is nominal, this is quite normal..... move away from the factory % is not wise!... also there are geometry issues here! in the area of centrifugal force albeit small.
