Newbie99 Posted August 29, 2003 Share Posted August 29, 2003 If I manage to get a set of 550 CC injectors from a UK supra, am I guaranteed they will fit my jap spec, as I just talked to Toyota and the chap came back with 8 different types of injectors!?!?!?!!? Also is the fuel rail different, from a jap spec to a UK spec? And finally if I upgraded to something bigger than 550's would I still require a resistor pack? Thanks. Link to comment Share on other sites More sharing options...
Guest Terry S Posted August 29, 2003 Share Posted August 29, 2003 Yes UK injectors will fit the JDM rail. You will only need a resistor pack if you buy LOW Impedance injectors ( such as the UK's). There are aftermarket bigger injectors such as Blitz which are High Impedance, and will therefore work without a resistor pack. If you want to reuse the existing rail you will need to buy side feed injectors. FYI the JDM injectors are 13.8 ohms whilst the UK's are around 2.8 ohms. Using LOW impedance injectors WITHOUT a resistor will cause injector/engine failure, as the injector/s will run dry eventually. Link to comment Share on other sites More sharing options...
dude Posted August 29, 2003 Share Posted August 29, 2003 Originally posted by Terry S Yes UK injectors will fit the JDM rail. You will only need a resistor pack if you buy LOW Impedance injectors ( such as the UK's). There are aftermarket bigger injectors such as Blitz which are High Impedance, and will therefore work without a resistor pack. If you want to reuse the existing rail you will need to buy side feed injectors. FYI the JDM injectors are 13.8 ohms whilst the UK's are around 2.8 ohms. Using LOW impedance injectors WITHOUT a resistor will cause injector/engine failure, as the injector/s will run dry eventually. Has anyone done this terry , surely everyone knows about fitting the resistor pack John:flame Dev Link to comment Share on other sites More sharing options...
Guest Terry S Posted August 29, 2003 Share Posted August 29, 2003 Originally posted by dude Has anyone done this terry , surely everyone knows about fitting the resistor pack John:flame Dev You'd hope so, but there is always one. Link to comment Share on other sites More sharing options...
dude Posted August 29, 2003 Share Posted August 29, 2003 John:flame Dev Link to comment Share on other sites More sharing options...
THOR Racing Posted August 31, 2003 Share Posted August 31, 2003 WITHOUT a resistor will cause injector/engine failure, as the injector/s will run dry eventually. That is the effect rather than the cause. Sorry to be pedantic but the resistance is required to set the drive current for the injector coils. The ECU has a low impedance (resistance) drive output which is current regulated by the external resistance. You need the same resistance for the ECU regardless of JDM or UK so you either make this up with 100% JDM Injectors at 13.8ohms or have 2.8ohm injectors and a 11ohm external resistor pack for UK. If you overdrive the coils (too much current caused by too low resistance) they will undoubtedly work for a while but on high load (WOT) they will get hotter and hotter as the coils heat up and eventually will fail. Look at the maths. 12V voltage feed to the injectors. (ground switched) Current = Voltage / Resistance So 12V / 13.8R = 0.87A But use 2.8R UK spec injectors and you get.... 12V / 2.8R = 4.29A 4.29A is far larger than the original 0.87A Either the injector coil will burn out or the output drive from the ECU would fail. (Modern ECU's are limited to a maximum current output which is probably why the injectors would last longer than you would first expect in this condition) Similarly you wouldn't fit high impedance injectors on the UK spec car without removing the resistor pack as this time you'd get too little current flow and the injectors would take longer to turn on and hence effect the fuel delivery. Regards Pete Link to comment Share on other sites More sharing options...
