Wiring diagram for the Throttle position sensor
Prof. Monkey
Thanks migster, wonder what the 4th wire is for?
the 4rth wire is for Idle circuit activation switch inside the tps ..you wont need it running a mustang TPS. Basicaly there is a a signal wire then a micro switch in the TPS for idle circuit.
