ADD Posted January 12, 2006 Share Posted January 12, 2006 god this is so annoying, if there is more than 1 person in the car it just steams up! any ideas what it could be? pollen filter maybe? Quote Link to comment Share on other sites More sharing options...
ADD Posted January 12, 2006 Author Share Posted January 12, 2006 ok so i am the only soop owner that gets this!!! Quote Link to comment Share on other sites More sharing options...
tbourner Posted January 12, 2006 Share Posted January 12, 2006 Doesn't the air con on hot clear it? Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted January 12, 2006 Share Posted January 12, 2006 Mine steams up ocassionally but doesn't sound like it's as bad. No idea what's causing it, have you got the air on recirc? apparantly this is a bad idea as the already moist air gets blasted straight back onto the windows again - make sure you've got it set to pull in air from outside, and if possible switch on the aircon too to dry it out. Quote Link to comment Share on other sites More sharing options...
Soo Posted January 12, 2006 Share Posted January 12, 2006 Our steams up lot of the time (no jokes please). Keep our a/c on most of the time and this clears it fine but don't like keeping it on as the idle sounds crap as it cuts in and out. Seems to be geting worse over the years - not a clue why - anybody ???? Quote Link to comment Share on other sites More sharing options...
Marco Posted January 12, 2006 Share Posted January 12, 2006 Have you got the air circulation on window? Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 12, 2006 Share Posted January 12, 2006 i think youll find this is a common problem , mine is like it all the time in this weather , air con clears it but is a pita , turn the ac off and back it comes . also loads of condensation , the front and rear screens are soaking wet inside most of the time , but its been like this ever sinse ive had the car , maybe the rubber seals arnt what they used to be , after all it is pushing eleven years old Quote Link to comment Share on other sites More sharing options...
edd_t Posted January 12, 2006 Share Posted January 12, 2006 Our steams up lot of the time (no jokes please). Keep our a/c on most of the time and this clears it fine but don't like keeping it on as the idle sounds crap as it cuts in and out. Seems to be geting worse over the years - not a clue why - anybody ???? im getting this cut in/out problem as well. is mega annoying. would be intrested to see if anyone knows why. my car does steam up, but like the others, put the aircon on and it sorts it out in a minute... Quote Link to comment Share on other sites More sharing options...
MARTIN R Posted January 12, 2006 Share Posted January 12, 2006 i think youll find this is a common problem , mine is like it all the time in this weather , air con clears it but is a pita , turn the ac off and back it comes . also loads of condensation , the front and rear screens are soaking wet inside most of the time , but its been like this ever sinse ive had the car , maybe the rubber seals arnt what they used to be , after all it is pushing eleven years old Mine does this as well, and I am sure its because the rubber seals and not as effective as they once were. Its the air con button to clear for me as well Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 12, 2006 Share Posted January 12, 2006 i think the ac is designed to cut in and out , not so that its on all the time , my mkiii supra had and int button , and also full on . so you could choose Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted January 12, 2006 Share Posted January 12, 2006 The cutting in / out is simply the compressor switching on and off I believe, causing a slight drain on the power, hence the revs rise to keep the engine running. Happened on every car I've owned with A/C, but only really noticable on the supra because the nurspec makes it soooo much louder Quote Link to comment Share on other sites More sharing options...
tbourner Posted January 12, 2006 Share Posted January 12, 2006 ETCS makes it more noticeable I assume. Although I suppose most modern cars have that. Quote Link to comment Share on other sites More sharing options...
merckx Posted January 12, 2006 Share Posted January 12, 2006 Have you got the air circulation on window? This works! Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted January 12, 2006 Share Posted January 12, 2006 I have been told that a lac of water in your raidiator can cause the interior to steam up excesivly. this happened in my dads Toy CarolaGti Quote Link to comment Share on other sites More sharing options...
merckx Posted January 12, 2006 Share Posted January 12, 2006 I have been told that a lac of water in your raidiator can cause the interior to steam up excesivly. this happened in my dads Toy CarolaGti Quote Link to comment Share on other sites More sharing options...
raymanuk Posted January 12, 2006 Share Posted January 12, 2006 god this is so annoying, if there is more than 1 person in the car it just steams up! any ideas what it could be? pollen filter maybe? Possibly the heavy breathing..... Quote Link to comment Share on other sites More sharing options...
jamesmark Posted January 12, 2006 Share Posted January 12, 2006 my windows steam up but thats cause my air con is not working thats the only thing that i loved about my ford was the electric front wind screen i think all cars should get this quicker than a/c as had loads of cars with a/c and i love it but the ford elec front windsreen tops it for de misting Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted January 12, 2006 Share Posted January 12, 2006 I heard once that heated front windscreens were actually a patent of Ford, don't know how true this is though. I agree it was very useful in my mondeo! Quote Link to comment Share on other sites More sharing options...
DamanC Posted January 12, 2006 Share Posted January 12, 2006 they have really small wires running in the screen that either heat up of conduct heat. Agreed a very usefull feature on fix or repair dailys, and unfortunately is patented Quote Link to comment Share on other sites More sharing options...
ADD Posted January 12, 2006 Author Share Posted January 12, 2006 i nearly always have my HRW on cause it is constantly steaming up! but i think that caus eive got a bad rust patch on ther rear boot! i hate puting the air con on too much cause it screws the mpg up!!! (doesnt it??) i know i know im tight! Quote Link to comment Share on other sites More sharing options...
ADD Posted January 12, 2006 Author Share Posted January 12, 2006 Possibly the heavy breathing..... Quote Link to comment Share on other sites More sharing options...
Marco Posted January 12, 2006 Share Posted January 12, 2006 I have been told that a lac of water in your raidiator can cause the interior to steam up excesivly. this happened in my dads Toy CarolaGti LMAO! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 12, 2006 Share Posted January 12, 2006 Commonest causes are heater set to recirculate, so the water vapours build up and the air is unchanged in the cabin, or a leaking heater matrix, do you lose ANY coolant at all, or notice a slghtly sweet and sickly smell in the cabin, especially when giving the engine some stick? The sickly smell is the antifreeze, (unless it's marijuana, but that's a totally different subject ) Quote Link to comment Share on other sites More sharing options...
monkey76364 Posted January 12, 2006 Share Posted January 12, 2006 What about cleaning the windows on the inside really well. This way at least any water or dirt ect will not be on the window to start with... and don't get in the car wet lol that's the worse. could always hire a dehumidifier from B&Q for the weekend pmsl Quote Link to comment Share on other sites More sharing options...
Supraman Posted January 12, 2006 Share Posted January 12, 2006 I recently renewed door/roof seals and noticed this cut it down by quite a bit. Quote Link to comment Share on other sites More sharing options...
