Cheap laptop with Serial port
carl0s
I have a cheap laptop which needs to go.
It's a HP Omnibook XE3. Pentium-III 850Mhz (not the celeron or AMD duron version).
Spec:
  • 14.1" TFT Screen
  • Pentium-III 850Mhz
  • 128mb SDRAM. It won't take the 256mb sticks I have here :(. Just about to try a BIOS upgrade on that though.
  • 20gb HDD
  • 10/100 Ethernet
  • 56k modem
  • CD-Writer
  • Floppy Drive
  • New-ish battery (old one also provided)
  • 9-pin Serial port
The battery was replaced not long ago, and holds a good charge. All cables and a carry case are included. The CDROM drive plays up a bit - it seems it can take a couple of open/closes to get it to recognise a disc, but I'm working on that now. I had hoped to replace the unit with a Toshiba DVD/CDRW drive but the bezel doesn't fit. If you're really not fussy then I could still do that but it'd have a light-grey bezel which looks silly but works well :)
Pictures to follow. One thing to note is that this is a very rubust machine - it has quite a hard-wearing design on the case.
It's running Windows 98SE. I have a spare XP Home license on a completely-knackered machine, and could move that across but it'd really work better with XP if it had more RAM.
b'have - I work for an IT asset management company - what sort of spec are you looking at (ie what is required? serial port etc)
Can get hold of pretty much anything I would have thought...
any chance of some kind of list being sent over to me? Or does one need to have an agreed account and purchase volumes?
