paulmann Posted January 7, 2006 Share Posted January 7, 2006 Morning Just had my NA diagnosed on a Rolling Road. It is totally standard. The guy said there was no det and it ran totally smooth through the runs. 1st two runs giving increasing power and the 3rd run sitting ontop of the 2nd. But it ran 20BHP less than standard. Is this expected for a 12 year old car with 60000 miles on clock? 205BHP with 184 FtLbs. He said it ran a little lean above 6400rpm. Thanks Paul. Quote Link to comment Share on other sites More sharing options...
Pete Posted January 7, 2006 Share Posted January 7, 2006 I'd say that's fairly normal for an older car to loose power over time. Who's to say the RR is spot on anyway Quote Link to comment Share on other sites More sharing options...
Jake Posted January 7, 2006 Share Posted January 7, 2006 205BHP with 184 FtLbs. 205bhp at the wheels? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 7, 2006 Share Posted January 7, 2006 205bhp at the wheels? That's a point! Quote Link to comment Share on other sites More sharing options...
paulmann Posted January 7, 2006 Author Share Posted January 7, 2006 At the fly wheel. NOw he said at the wheel s the bhp was 165. that means he has used 25% to work it out right? but that far too high for rwd, maybe 4wd? am i correct. maybe meaning i am running less power. i do n't know to be honest. just guessing. Quote Link to comment Share on other sites More sharing options...
Jake Posted January 7, 2006 Share Posted January 7, 2006 At the fly wheel. NOw he said at the wheel s the bhp was 165. that means he has used 25% to work it out right? 20% Quote Link to comment Share on other sites More sharing options...
Clarkey Posted January 7, 2006 Share Posted January 7, 2006 Did they give you a dyno chart plotting your AFRs ? Quote Link to comment Share on other sites More sharing options...
suprasport Posted January 7, 2006 Share Posted January 7, 2006 At the fly wheel. NOw he said at the wheel s the bhp was 165. that means he has used 25% to work it out right? but that far too high for rwd, maybe 4wd? am i correct. maybe meaning i am running less power. i do n't know to be honest. just guessing. yep your right 24. something% thta is high but someone will tell you exactly Quote Link to comment Share on other sites More sharing options...
Jake Posted January 7, 2006 Share Posted January 7, 2006 someone will tell you exactly 19.5121951219512% drivetrain losses Quote Link to comment Share on other sites More sharing options...
suprasport Posted January 7, 2006 Share Posted January 7, 2006 19.5121951219512% drivetrain losses didn't see your post you missed a 034 at the end btw Quote Link to comment Share on other sites More sharing options...
_Rob_ Posted January 7, 2006 Share Posted January 7, 2006 I thought drivetrain losses were different to every car, dependant upon wheel and tyre size, drive train wear etc, and a standard figure of 20% wouldnt give an accurate conversion. AFAIK to get an accurate fly readout dont you need to have the engine bench dyno'd? rarther than rolling road'd? Quote Link to comment Share on other sites More sharing options...
Jake Posted January 7, 2006 Share Posted January 7, 2006 I thought drivetrain losses were different to every car, dependant upon wheel and tyre size, drive train wear etc, and a standard figure of 20% wouldnt give an accurate conversion. AFAIK to get an accurate fly readout dont you need to have the engine bench dyno'd? rarther than rolling road'd? Yep. Flywheel figures are total guesswork and frankly meaningless, unless meaured on a bench dyno. Quote Link to comment Share on other sites More sharing options...
paulmann Posted January 7, 2006 Author Share Posted January 7, 2006 i will scan in the pages for monday. Quote Link to comment Share on other sites More sharing options...
