gaz1 Posted January 7, 2006 Share Posted January 7, 2006 thinking at changing my alarm ,was told you can get one that when armed will make your windows go up, and also you can start the engine from the alarm fob, mmmm is this right and if it is where do i get my hands on one of the little beauties, and a rough idea of cost with fitting Link to comment Share on other sites More sharing options...
chilli Posted January 7, 2006 Share Posted January 7, 2006 hi, I think any decent modular alarm should be able to do that for you, and more. You can add the extras as and when you require them. For example the toad ai606 (which is a good, extentable alarm) has: >3 timed or constant remote controlled outputs for boot release, headlamp illumination, total closure etc which can be wired to close all the windows (sometimes they call these window lifters, really they are just relays IIRC). >Two 4 button transmitters I think this, with the outputs above could be wired for remote start. The basic supply and fitting, probably around £250 or so (bit of a guess) and a bit extra for the window lifters etc, shouldn't be expensive. Link to comment Share on other sites More sharing options...
gaz1 Posted January 7, 2006 Author Share Posted January 7, 2006 just rang about it was quoted £1150 jeez clifford total closure and intellistart ouch Link to comment Share on other sites More sharing options...
Pete Posted January 7, 2006 Share Posted January 7, 2006 ring someone else then. Link to comment Share on other sites More sharing options...
ivan Posted January 7, 2006 Share Posted January 7, 2006 Try these for one: http://www.yourcarparts.co.uk/trolleyed/68/ Link to comment Share on other sites More sharing options...
edd_t Posted January 7, 2006 Share Posted January 7, 2006 ive got a mate in southend thats pretty cheap, hes a qualified toad fitter if you want his details Gaz. Link to comment Share on other sites More sharing options...
Adam Posted January 7, 2006 Share Posted January 7, 2006 just had mine done but without the engine start up. he was good and not badly priced. he doesn`t have an e mail address but if your intrested e mail me and i will put you in contact with him. [email protected] he is local to the kent area to. Link to comment Share on other sites More sharing options...
TrickTT Posted January 7, 2006 Share Posted January 7, 2006 I paid £350 for my cat1 clifford 650 last year, and another £200 for intellistart. reckon on another £150 - £200 for windows and boot. All fitted price obviously. Link to comment Share on other sites More sharing options...
chilli Posted January 7, 2006 Share Posted January 7, 2006 last time I had window lifters added it cost me £70 for a pair, this whole set up shouldn't really sting you more than £350, shop around... Link to comment Share on other sites More sharing options...
Matt Harwood Posted January 7, 2006 Share Posted January 7, 2006 I can do the Concept 650 for £340, Intellistart for £140, (when installed at the same time), Window closure for £50, boot release can be a bit tricky, but no more than £70. (Not one of my favourite/recommended things though). Even better, as I'm 'slightly' famillier with Supra's, I know how to correctly wire up the immobiliser circuits on a Supra. Something thats very often done wrong. And I'm in Kent Link to comment Share on other sites More sharing options...
Pig Posted January 7, 2006 Share Posted January 7, 2006 Why wouldnt you recommend having the boot dont matt? Oh and how much to fit my E-manage ultimate mate? Has mark spoken to you about it yet? Link to comment Share on other sites More sharing options...
Matt Harwood Posted January 7, 2006 Share Posted January 7, 2006 When you fit a boot release, you have to fit a solenoid to pull the release cable. It has to be fitted in such a way that allows the release cord to work at the front as normal, but in doing this, it makes the boot harder to shut as the latch cable is always under tension one way or the other. It's not really a 'big' deal, but whenever I shut other peoples boots, I always wish mine would shut that easily.... IYSWIM..... YHM re the E-manage... Link to comment Share on other sites More sharing options...
