chris aka fonz Posted January 5, 2006 Share Posted January 5, 2006 Just noticed my car was beeping , 2 beeps then pause then 2 beeps then pause and so on , i tryed my key fob to unlock and open the car but it wouldnt work , i then opened the door with the key and set the alarm off . I couldnt disarm it with the key fob , im pretty sure its a 450 or 500 series clifford alarm . Could it just be my battery has gone dead in my fob , would that make my car beep tho ? Im puzzled ! Quote Link to comment Share on other sites More sharing options...
Dragon Posted January 5, 2006 Share Posted January 5, 2006 Just noticed my car was beeping , 2 beeps then pause then 2 beeps then pause and so on , i tryed my key fob to unlock and open the car but it wouldnt work , i then opened the door with the key and set the alarm off . I couldnt disarm it with the key fob , im pretty sure its a 450 or 500 series clifford alarm . Could it just be my battery has gone dead in my fob , would that make my car beep tho ? Im puzzled ! that won't make your car beep, is the car battery ok? Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted January 5, 2006 Share Posted January 5, 2006 It does sound like a flat car battery to me. Quote Link to comment Share on other sites More sharing options...
Duffers Posted January 5, 2006 Share Posted January 5, 2006 The system will beep at you when locking / unlocking if the fob battery is low but I think it's just one single low tone - not constant beeping and pausing. Hope you get it sorted, hope it is just something simple like the car battery! Quote Link to comment Share on other sites More sharing options...
chris aka fonz Posted January 6, 2006 Author Share Posted January 6, 2006 i checked the battery and its flat as a pancake , ill charge it up and reconnect it . should the alarm be as before or will it need reseeting or programming ? Im a dumbass with car electronics Quote Link to comment Share on other sites More sharing options...
suprasport Posted January 6, 2006 Share Posted January 6, 2006 i checked the battery and its flat as a pancake , ill charge it up and reconnect it . should the alarm be as before or will it need reseeting or programming ? Im a dumbass with car electronics if it is the battery alarm will be fine once recharged Quote Link to comment Share on other sites More sharing options...
chris aka fonz Posted January 8, 2006 Author Share Posted January 8, 2006 It was the battery on the car , and now the alarm is fine ! Probably should of checked before wasting peoples time sorry guys Quote Link to comment Share on other sites More sharing options...
veilsideTT Posted January 8, 2006 Share Posted January 8, 2006 My battery died on my supra and it was left for a few months. Since then i couldn't get the alarm to "beep" when i set and unset it, and the self powered siren doesn't sound when you disconnect the battery. Strangely enough though, i have since changed the battery again after leaving it too long without starting (never learn do we) and now it all works again, beeps en all! Weird! Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted January 8, 2006 Share Posted January 8, 2006 My battery died on my supra and it was left for a few months. Since then i couldn't get the alarm to "beep" when i set and unset it, and the self powered siren doesn't sound when you disconnect the battery. Strangely enough though, i have since changed the battery again after leaving it too long without starting (never learn do we) and now it all works again, beeps en all! Weird! The siren batterys take their charge ONLY when the engine is running. So if you don't use the car for an extended period, the siren battery will go flat. Generally, driving the car will recharge the siren battery. If you ever find that you lose the chirps, but the siren does sound when triggered, that's telling you that the battery in the siren is knackered and the siren needs replacing. Quote Link to comment Share on other sites More sharing options...
veilsideTT Posted January 8, 2006 Share Posted January 8, 2006 thanks matty! ps, whos hissing sid? Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted January 11, 2006 Share Posted January 11, 2006 ps, whos hissing sid? The bravest animals in the land are Captain Beaky and his band - that's Timid Toad, Reckless Rat, Artful Owl and Batty Bat." . . . . It's a childhood memory really. Something Noel Edmonds was involved with on the radio when I was a kid. At the time it seemed my whole class and everyone I knew were following it. Hissing Sid was 'alledgedly' an evil snake. However, like all good baddies, Hissing Sid had his followers that believed "Hissing Sid in Innocent!" Hence the association with Dude.... I'll get my coat... Quote Link to comment Share on other sites More sharing options...
veilsideTT Posted January 11, 2006 Share Posted January 11, 2006 ah, i see! you learn something everyday! Quote Link to comment Share on other sites More sharing options...
