psymon Posted January 5, 2006 Share Posted January 5, 2006 Guys. I ordered the entire rear for the Supra, courtesy of your friend and mine Nic. Has anyone fitted all of this themselves, if so any long did it take you. Need a rough guest, as a) its cold outside b) she's my everyday runner Also many thanks for a great saving cheers Nic Link to comment Share on other sites More sharing options...
Paul Whiffin Posted January 5, 2006 Share Posted January 5, 2006 Nothing to hard about it unless something is seized up, we are getting a lot of Supra's coming with the lower arm camber bolts seized solid, they can be a right pain in the arse to get off. Good luck! Link to comment Share on other sites More sharing options...
DShox Posted January 5, 2006 Share Posted January 5, 2006 i'd set at least a weekend aside. jacking the thing up and taking the wheels off, and making it safe takes a bit of time. daylight goes against you by 330. get your axle stands ready and some wd40 - you may have to spray the bolts and leave em for a couple of hours at least. what helps is having a hollow steel tube to slide onto the end of the ratchet for extra leverage - works a treat! Link to comment Share on other sites More sharing options...
Nic Posted January 6, 2006 Share Posted January 6, 2006 Nice one Simon, good luck with the install Link to comment Share on other sites More sharing options...
