THOR Racing Posted January 15, 2002 Share Posted January 15, 2002 Please find new sections on my personal web pages showing pictures of the odometer and conversion of the Jap sepc to UK spec by moving two surface mount resistors, active spoiler assembly (tray,arm and motor units), the headlight bulbs and how they differ from the 9005,6 standard plus pictures of my boot hatch rubbers (replaced at the weekend) http://www.trlperformance.com/supra sections "Speedometer Conversion" and inside at the bottom is the odometer stuff. "Active Spoiler" "Rear Hatch Rubbers" "Headlights" all in the "useful stuff" section Hope it's of some use to some people. Also if you're into bikes, while I'm here take a look at http://www.trlperformance.com/bikes.html , Terry Steele has some for sale. Don't contact me though. Regards Pete Quote Link to comment Share on other sites More sharing options...
mrboost Posted January 15, 2002 Share Posted January 15, 2002 Good Work Peter! Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted January 15, 2002 Share Posted January 15, 2002 Hi Pete, the first link does not work in Opera, I just get a page of source. Had another play, looks like the Supra file doesn't have a file name extension on it, guess it should be html. Why two methods of changing the odo display? Is there any advantage to doing the 'proper' conversion by moving the resistors over the 'cheating' method? Quote Link to comment Share on other sites More sharing options...
Digsy Posted January 15, 2002 Share Posted January 15, 2002 Nice work, Pete. I've got a question about the headlights. Do the differences betwen the bulb holders mean that the UK spec bulbs won't fit? I know that one of the front bulbs (The sidelight or foglamp I think) is difficult to source, but you are talking about the main headlight? Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted January 15, 2002 Author Share Posted January 15, 2002 >looks like the Supra file doesn't have a file name extension on it, >guess it should be html. I specifically made it without an HTML extension so I didn't have to keep typing it in when I gave someone the link. I can always make two copies or something. I'm not a WEB wizzard. >Do the differences betwen the bulb holders mean that the UK spec >bulbs won't fit? No, not unless you cut the locating tab out of the connector (attached to the wiring loom) I should have taken a picture of this as well I guess. Maybe when I next in that area of the car again I will. The lights shown are the Dipped Headlights (which are virtually identical inshape and form to the main beam headlights) The FOG's I've got no idea about as I've never actually had cause to take them out. The sidelamps are normal bulbs (I had the number at the weekend and have just fogotten it) but you can get these from any motor factor. They are all replaceable without removing anything! Regards Pete I know that one of the front bulbs (The sidelight or foglamp I think) is difficult to source, but you are talking about the main headlight? Quote Link to comment Share on other sites More sharing options...
Digsy Posted January 15, 2002 Share Posted January 15, 2002 Cheers, Pete. So what does everybody do when they blow a headlight bulb? Modify the connector like Pete suggests? Quote Link to comment Share on other sites More sharing options...
Alex Posted January 16, 2002 Share Posted January 16, 2002 Ahhhhh...this would explain why the Main Beam headlight supplied to me didn't fit...it was for a UK Spec...didn't think they'd change the bulb connectors....oh well guess that solves that, but it's still the wrong bulb (Bog Standard not Premium Xenon as per the frikin order). The 9006 in Japan must be identical to the 9005 but in the UK we (sensibly) have differences making sure retards like me can't get the two mixed up! Cheers for that Pete. Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted January 16, 2002 Author Share Posted January 16, 2002 You'll find the 9006 and 9005 have the same connectors just different beam/lens/lights characteristics. So A dipped beam bulb would fit into the main beam bulb connector so make sure you have them the correct way around. The connectors differ from the UK to Jap spec but both main and dipped connectors are the same as one another. Was that clear??? It really is no trouble at all to just slice off a bit of the plastic in the connector to make it dual fitment (Jap or UK) the locating tabs don't effect it's connection as there is a clip on the opposite side which still firmly holds the bulb in. Regards Pete Quote Link to comment Share on other sites More sharing options...
Alex Posted January 16, 2002 Share Posted January 16, 2002 Indeed, I thought they had sent me the wrong type and version of bulb but its just the version they got wrong....thanks for clearing that up. Quote Link to comment Share on other sites More sharing options...
