Supra's with 100k+ miles and engine rebuilds
rpslaughter1982
So long as its been properly serviced it should be good for 300k+, I know a couple that are over 200k and going strong.
The thing most likely to be worn is the turbos (budget £1k), a bottom end rebuild on a supra is extremely rare, its mainly done by those going for big power (600bhp+)
107K miles, brought it with 21K miles 3 years ago. The only thing that ever went wrong with my one was a broke drivers window cable.
Servicing is the key issue. I always use toyota parts, and change my gearbox oil every 10K. (auto)
SBK
What would a new uk engine cost, any ideas ?
Fully built with head so you could just swap all the ancillaries over rather than rebuild your worn out one.
dunk
Bottom end (Block, pistons, rods etc...) as stated about 2k
Head I believe Arnout will do a fully built head swap for £1600.
Ancillaries pass....but a PAS pump is about £300...then there's oil pump, water pump, AC pump etc etc.
Thanks Alex
I was actually thinking more along the lines of Toyota doing a brand new unit that you just swap all your bits too as long as there in good working order that is.
I'll give Mr T a call and see if they do anything along those lines.
dunk
Just been on the phone to Toyota and Brand new UK parts
Short Engine
Block, Sump, Pistons, Rods, Crank
all built = £1851.15 + vat
Partial Assembly
The above but with cylinder head fitted
and ready to bolt in = £6,036.36 + vat
dunk
Short Engine
Partial Assembly
dunk
Those are crazy figures! Surely you'll need to add manifolds, turbos, and possibly ignition to all all of that!
PS: SBK you finally got bored of the old smartgroups then?
Yeap, 30K a year. I brought my mkiv as a company car to drive up and down to Wallington. Faultless.
Ark - I still try and go onto smartgroups but as I retrieve mail fro mthe web, there are always problems. Always been on here, but only recently paid my £10.
I love all sites that involve supras and cars - Petrol mad :-)
SBK
Youd use most of the bolt on parts that are already on your old engine
so you would have manifolds, throttlebody etc.
You could go to town and do the turbo's if you were feeling really extravagent:D
Also these aren't according to Murley Toyota in Stratford reconditioned units, there completely brand new.
Need a price from someone to rebuild a complete engine to the same o/e spec as the Toyota engines to get a comparison.
Not a clue what any of our specialists here would charge so worth more investigation i think.
Also youve got to allow £?'s to do the removal and installation.
dunk
I do think you have very little faith in the supra lump! you're really thinking worst case scenario! These things are bullet proof if maintainted properly, as said before 300k! so worry bout milage too much when buying! there are low milage ones around, but most are around if not over 100k and no one really thinks twice!
Guest Terry S
Im sure Terry was gona stock rebuilt engines,or was looking in to it a while ago.
We have done a few now, new short block, uprated rods, rod bolts. Works really well. Not stocking them as there simply isnt the demand but the turn around is pretty quick.
