lui Posted January 4, 2006 Share Posted January 4, 2006 Im running Goodyear Eagle F1's 235 X 40 X 18 fronts & 275 X 35 X 18 rears what should the correct tyres pressures be for these ?????????? Quote Link to comment Share on other sites More sharing options...
AJI Posted January 4, 2006 Share Posted January 4, 2006 tyre pressures will vary from car to car depending on the weight .... generally for a Supra it is around the 36psi region. Mostly it is a gauge of how your tyre is wearing away. And handling can improve or worse in wet or dry on the same pressure. So I always tell everyone to experiment within a safe pressure range to what suits you best. So try anything from 32psi upto 40psi... but keep from and rear at similar pressure. I run 38psi front and 36psi rear on my UK-spec as this gives the best tread wear across the whole of the tyre. Quote Link to comment Share on other sites More sharing options...
chilli Posted January 4, 2006 Share Posted January 4, 2006 I've been wondering this too and my tyres are the same sizes as yours. So far I'm at 34 psi all round and that seems good. I think slightly more at the front vs back might work better though, maybe 32 rear 34 front or 34 rear 36 front. Having grip issues with the rear though so tending to keep the PSI down a touch. Quote Link to comment Share on other sites More sharing options...
supRo Posted January 4, 2006 Share Posted January 4, 2006 I run 36 up front and 34 or 35 at back (34 for bit more grip) Quote Link to comment Share on other sites More sharing options...
Parksy Posted January 4, 2006 Share Posted January 4, 2006 I run 32 all round, mainly because with the 18s' it is a hard ride with higher pressures Quote Link to comment Share on other sites More sharing options...
supRo Posted January 4, 2006 Share Posted January 4, 2006 As you can see Lui - People use various pressures. Best to experiment using the above pressures and see how you go, keeping an eye on uneven wear. Ro Quote Link to comment Share on other sites More sharing options...
JohnA Posted January 4, 2006 Share Posted January 4, 2006 Usually the manufacturer's recommended pressures are a good starting point, and then you experiment with a few psi less here and there. You soon find the optimal setup for your conditions. 36psi all around is for safe autobahn speeds on stock 17"wheels. For plodding around town you could perhaps do with a few psi less. Quote Link to comment Share on other sites More sharing options...
Wez Posted January 4, 2006 Share Posted January 4, 2006 On another note isnt 235 front and 275 rear to big a difference? Stock is 235 front and 255 rear, how does that affect the handling and characteristics of the car? Quote Link to comment Share on other sites More sharing options...
Mike Posted January 4, 2006 Share Posted January 4, 2006 Stock wheels, 32psi all round here..... Quote Link to comment Share on other sites More sharing options...
chilli Posted January 4, 2006 Share Posted January 4, 2006 On another note isnt 235 front and 275 rear to big a difference? Stock is 235 front and 255 rear, how does that affect the handling and characteristics of the car? I think this is a pretty common setup on supra's with aftermarket wheels isn't it, seems to work well on mine but still not enough grip at the back! Quote Link to comment Share on other sites More sharing options...
JohnA Posted January 4, 2006 Share Posted January 4, 2006 I wouldn't automatically assume that a 275 would grip better than a 255 (of the same compound) For starters are the wheels wider than stock? Quote Link to comment Share on other sites More sharing options...
chilli Posted January 4, 2006 Share Posted January 4, 2006 they sit nicely on 10J rims - they are wider, lower profile and larger (18") - put it this way, I won't be swapping them for 255s! In fact my next set might be 285s I think. Agreed a bad match of tyre/wheel is worse than stock, I think 275/285 on ~10J rims is a good match though. Quote Link to comment Share on other sites More sharing options...
JohnA Posted January 4, 2006 Share Posted January 4, 2006 yeah, 275 is fine on 10" width Quote Link to comment Share on other sites More sharing options...
kaapstad82 Posted February 19, 2007 Share Posted February 19, 2007 noticed the car had oversteer i think you call it that,changed the pressure on the rear 255x40x17" tyre to 34psi ,changed the front 235x45x17" tyre to 36psi, what a diffarence pull away off roundabout no more problems and with a slow drzzle on the road aswell. the pressure was between 30-32psi all round with the feeling of turning from the rear exiting the roundabout (i dont mean sliding from the rear either). will now stick with those pressures ,what a total change in the hadling of the car,thanks for all your advice above[GRIN][/GRIN] Quote Link to comment Share on other sites More sharing options...
AlanM Posted February 19, 2007 Share Posted February 19, 2007 I have same size as you, 36 front 34 back Quote Link to comment Share on other sites More sharing options...
Class One Posted February 19, 2007 Share Posted February 19, 2007 Holy thread resurrection Batman! Quote Link to comment Share on other sites More sharing options...
JohnA Posted February 20, 2007 Share Posted February 20, 2007 Nice to know that the manufacturer's recommended pressures are an improvement over other, randomly selected values. Quote Link to comment Share on other sites More sharing options...
