smithaldo Posted January 3, 2006 Share Posted January 3, 2006 Hi i think my car has run out of oil somehow i keep getting the light on in the middle of the rev counter come on. so have had a look round under the bonnet and found that most fluids are running low. steering fluid, oil, washer etc etc. can anyone help me out with which oil to use (viscosity etc) ? its an na supra also have uk spec lights to fit how easy is it to get to the bottom screws? looks like a bit of a mare thanks in advance Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 3, 2006 Share Posted January 3, 2006 Brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrake fluid! Clicky Generic type IV ATF fluid for the PAS Water and screenwash for the screenwash I use Toyota 4life for coolant but some people use generic antifreeze Oil is a hot topic, do a search And finally, brake fluid really depends bigtime on what was in there originally - if you don't know then perhaps a nice flush and replacement with Motul RBF600, it's the daddy of brake fluids for us. -Ian Quote Link to comment Share on other sites More sharing options...
Bob Posted January 3, 2006 Share Posted January 3, 2006 Mate, you really should check your fluids levels at least once a week! Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 3, 2006 Share Posted January 3, 2006 For gods sake check everywhere for leaks. You should not be 'running out' of fluids at all...... Quote Link to comment Share on other sites More sharing options...
