Gamer Posted January 2, 2006 Share Posted January 2, 2006 Can someone in the know please advise me on the correct tyre sizes to use on the following size wheels. 18 x 9.5 +40mm offset, 18 x 10.5 +45mm offset I am assuming that the correct sizes are: 255/35/18 front 275/35/18 rear I do not want to have a stretched tyre look but on the same token I do not want to have clearance issues mainly with the fronts being 9.5", that is making me a bit nervous. I am currently running a 265/35 tyre on the front but the wheel is 'only' 9" so a bit concerned about the extra .5", hence dropping the tyre down to a 255 section. Will that do the trick ? By the way these are the ones I will be getting. I think these would be better suited as my 'everyday' wheels and my current ones being used for shows/shoots ect. Black Volk TE37 Link to comment Share on other sites More sharing options...
merckx Posted January 2, 2006 Share Posted January 2, 2006 Aren't 9.5" & 10.5" a little wide for those tyre sizes. Shouldn't you be starting with the tyre sizes you require based on grip/handling and then choosing the correct wheel widths. I thought it would be better to go for 9" & 10" wheels with maybe 245/255 front and 275/285 rear, at least the tyres will protect the wheel a bit more. Link to comment Share on other sites More sharing options...
Ian W Posted January 2, 2006 Share Posted January 2, 2006 yer, tyres look a little narrow for the wheel widths...possibly 265s and 275s on the rear? Link to comment Share on other sites More sharing options...
Gamer Posted January 2, 2006 Author Share Posted January 2, 2006 Fair enough, 265/35 front- 275/35 rear is what I am currently running on a 9" front and 10" rear wheel. I get slight rubbing on full lock, just a bit of the fender lining really nothing major. So that is why I thought it better to drop down to a 255 section. The wheels are being purchased in a private sale that is why I have no say in getting a 9" front wheel. Yes, I could order a new set from Japan but not for the price I will be getting these and also I will not have the standard 8-10 week wait. Link to comment Share on other sites More sharing options...
Syed Shah Posted January 2, 2006 Share Posted January 2, 2006 255 front, 285 rear IMHO. A 265 is better suited to a 10" rim than a 9.5" rim. Link to comment Share on other sites More sharing options...
