Made a nice field harness for £50!
Duffers
Proper pleased! Bought an old HKS F-Con 4 ECU from eBay for £50 that I couldn't do anything with and after a bit of metering out and soldering - I've managed to make up a fully working "straight-thru" field harness for £50! It works a treat!! Pity I already hacked my factory wiring to install my FCD and AFR! Oh well, just need to get those put back as they were and run my add-on stuff from my new field harness! Just thought I'd share that with you in case you had an old HKS ECU going spare - make a field harness with it and throw the ECU in the bin! :D
Here is the harness before I soldered it all together!
Paul
