Box next to ECU
Wez
Hey Guys,
Does anyone know what the box is next to the ECU in the passanger footwell?
Its to the left of the ECU with a toyota badge on it and about half the size of the ECU and connected via a multiplug similar to the ECU.
Regards
Wez
:cool:
Does the Trac ECU use the ABS sensors and is there any link between the Trac ECU and the ABS ECU that could cause braking problems if the Trac ECU is removed???
Just asking for those who are taking out the Trak ECU.
how many ecu`s are there
main ecu in passenger footwell
traction ecu next to main ecu
abs ecu behind radio
auto gearbox ecu under center console box
active spoiler ecu (for posh supra`s)
why would you need to take ecu out, cant be weight saving?
if you taking the traction ecu out why dont you just pull the trac fuse
I will be going single at some stage but not yet, i have done the install and base setup myself and also done some of the basic mapping myself, only mapped 0 - 4000 at the moment and i have a friend who does alot of mapping looking at it tomorrow.
I have basically got it installed and made the car driveable, i have been monitoring the knock etc and have made sure its still a little rich to be safe but so far its all good.
:flame Dev
