Who is rebuilding theur supra this winter
Lucifer
Building a second engine, similiar spec to Lucifer, single, built box etc. Leaving the body stock as a sleeper, I don't want any kit to slow me down. Decided to build another so I was not under pressure to complete to use the car. Ripping the old engine out sounded like a good idea after the Skyline transplant into my sons car.
Got all the parts i need to repair the front end damage on mine now, thanks mainly to the various cars thet have been broken on the forum. Just got to grease the taxmans palm in january, then it's full steam ahead.
Hopefully on the road for the summer:ecstatic:
How is the Ultimate over the old version?
Gav
Good. Getting there. I'm working with Digsy to sort out some electronics that it'll inteface with to cure the 3000-4000 rpm freakiness. I'm gonna have a stab at the upping-the-rev-limit stuff once the opportunity to test presents itself. I just found the launch control won't work though as the stock ECU doesn't like the ignition cut - it faults out and cuts the injectors to, I think, prevent CAT damage. Ironic as they are in the loft.
-Ian
