Gordon F Posted January 14, 2002 Share Posted January 14, 2002 Should this come on with all the other warning lights when the ignition is turned on? If so, is it possible I have a blown fuse, and which one is it? Thanks:) Link to comment Share on other sites More sharing options...
Flipfinger Posted January 14, 2002 Share Posted January 14, 2002 I'm pretty sure it's meant to come on for a second or so, then switch off when you start the engine. Or mine is also effed... Link to comment Share on other sites More sharing options...
Digsy Posted January 14, 2002 Share Posted January 14, 2002 It is indeed meant to illuminate for a moment when you key on. Link to comment Share on other sites More sharing options...
GavinL Posted January 14, 2002 Share Posted January 14, 2002 Quote: from Gordon Flynn on 4:33 pm on Jan. 14, 2002[br]Should this come on with all the other warning lights when the ignition is turned on? If so, is it possible I have a blown fuse, and which one is it? Thanks:) or the bulb has blown Link to comment Share on other sites More sharing options...
Matt Harwood Posted January 14, 2002 Share Posted January 14, 2002 If you've removed the top section of dash recently, make sure the top right plug is securly back in place. Link to comment Share on other sites More sharing options...
Phil Wall Posted January 14, 2002 Share Posted January 14, 2002 Another simple check, just pull the ABS relay from its socket in the little black box on the off side front turret, then put it back, to ensure good contact. Link to comment Share on other sites More sharing options...
Simon Posted January 16, 2002 Share Posted January 16, 2002 All the fuses are also identified in the lid of the fuse box cover. Link to comment Share on other sites More sharing options...
Matt Harwood Posted January 17, 2002 Share Posted January 17, 2002 Any luck yet Gordon? Link to comment Share on other sites More sharing options...
Gordon F Posted January 17, 2002 Author Share Posted January 17, 2002 I havent used the car this week Matt so I was going to look at it this weekend. I did have a problem with the top right dash plug...the lights would only work when I wiggled it about (not the ABS light though). I wedged a cable tie alongside the plug and the other 3 lights are ok. Will check bulbs, relays, fuses etc on Saturday..will let you know! Link to comment Share on other sites More sharing options...
